Does not open websites
I have Pi-Hole version 5.0 installed on Raspberry Pi ZERO W (Raspbian operating system). The problem is that websites often don't open the first time. You need to refresh once or twice. How can I fix it?
Look in your query log to see what domains are being requested and if they are being resolved. These tools can also help:
This is not a problem with blocking individual sites. I do not open the website, I do refresh and the website is.
You're probably using more than just Pi-hole as the client DNS.
I have a Hitron hitgn cgnv4 router and DHCP disabled in it.
Dhcp I have included in PiHole and he is the only dns.
Check your clients and make sure they only have Pi-hole as the sole DNS server.
Pi-hole is the only dns server.
Then it should be working.
If you were to provide us with more information and the data requested in the template that was deleted when you opened the thread then we may be able to provide troubleshooting options.
