This will give you safe and secure access for your Pi-hole from everywhere. This cannot be stressed enough.
I noticed typo above and wanted to correct but couldnt find:
title: Prerequisites
description: Operating system and network requirements
last_updated: May 25 2020
### Hardware
Pi-hole is very lightweight and does not require much processing power
- ~52MB of free space
- 512MB RAM
Despite the name, you are not limited to running Pi-hole on a Raspberry Pi.
Any hardware that runs one of the supported operating systems will do!
### Software
Pi-hole is supported on distributions utilizing [systemd](https://systemd.io/) or [sysvinit](https://www.nongnu.org/sysvinit/)!
This file has been truncated. show original
Also maybe below is more clear:
By default, FTL chooses a random source port in the range of 1,024 - 65,535 (= 64,512 possibilities) to maxime resilience against forged DNS answers.
DL6ER
August 21, 2020, 3:16pm
2
Go ahead if you like. This ensures author contribution is correct. This has not yet landed in master
, it is still on a branch with PR. Check out the same file on branch fix/ports
### Hardware
- Min. 2GB free space, 4GB recommended
- 512MB RAM
### Software
