Docker Swarm Possible?
#1
I have pi-hole running on one of the nodes on my raspberry pi cluster (using ClusterHat).
It would be advantageous to have some redundancy built in by having pi-hole running across several replicas of the cluster using Swarm.
Has anyone tried to run it across a Docker Swarm on Raspberry Pi’s?
Any special configuration required in creating the service?
#2
I use Docker containers on VM’s and got it to work using the command here: You can read about the next issue I had in my thread. No reason the same thing wont work on the PI’s
cheers
