i installed docker from pihole on raspberry raspbian .
few days later went to the console and upgrade PH. stays in restarting mode
yesterday i stopped the container and when i restarted it i not longer can get it running
3ba9709acb42 pihole/pihole:4.1_armhf "/s6-init" 7 days ago Restarting (1) 45 seconds ago pihole
log
fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 20-start.sh: executing...
/root/ph_install.sh: line 34: setupVars: readonly variable
[cont-init.d] 20-start.sh: exited 1.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] syncing disks.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] 01-resolver-resolv: applying...
[fix-attrs.d] 01-resolver-resolv: exited 0.
[fix-attrs.d] done.
i see exit code 1 uopn inspecting the container ?
any help appreciated
