gunhedz
1
After an update via latest and watchtower from v5.3.4 to v5.4 Pi-hole did not start anymore.
Checking the logfile there is a startup loop, because of the following during Startup checks:
iproute2 and iproute packages were not found in APT repository
After reverting back to v5.3.4 everything is working again.
regards
Did you use the latest
tag or v5.4
tag?
gunhedz
3
I used to use latest
and had now to manually use v5.3.4
, to pull the version before, which is working.
It's a better idea to use pinned versions and not the latest
tag. Mostly for things like this but it's still a better practice to not use latest
What OS is docker running on?
gunhedz
5
Hi Dan, I am using dietpi arm 64bit which is based on Debian Buster (10.7) arm 64bit on a raspi3.
regards
tk3k
6
Same behavior here on Ubuntu 20.04 LTS.
Plaidy
7
Same behavior with Pi-hole running in a docker container on a Raspberry Pi4 with Ubuntu 20.04
gunhedz
9
thx, that fixed my problem!
I had a read-only mount on /etc/resolv.conf
with the first entry: nameserver 127.0.0.1
changing that to another public DNS or my routers DNS fixed the aborting.
many thx Dan and yubiuser!
regards
system
Closed
10
