Hi I already have a docker pi hole running perfectly on a PI but I want to move some load from that pi to a laptop im not using. I install first Ubuntu server and then Fedora server and still having exactly the same problem if I forward the ports in the docker compose everything works fine but since I need DHCP I have tu use network host. At first I was having a problem with system-resolved and the port 53 not binding but I resolved that uncommenting ```
DNSStubListener=no
in the resolved.conf file. I try it without DHCP server only the DNS and still no luck. I think I'm missing something but I don't know what it is
docker compose
version: '2'
volumes:
etc_pihole:
etc_pihole_dnsmasq:
services:
pihole:
image: pihole/pihole:latest
container_name: pihole
network_mode: host
restart: unless-stopped
hostname: linuxbookpro
cap_add:
- NET_ADMIN
volumes:
- etc_pihole:/etc/pihole:rw
- etc_pihole_dnsmasq:/etc/dnsmasq.d:rw
environment:
- WEBPASSWORD=password
- ServerIP=10.1.11.10
- VIRTUAL_HOST=pi.hole
- PROXY_LOCATION=pi.hole
- TZ=America/New_York
dns:
- 127.0.0.1
- 1.1.1.1
docker log
::: Starting docker specific checks & setup for docker pihole/pihole
[i] Installing /etc/dnsmasq.d/01-pihole.conf...
[✓] Installed /etc/dnsmasq.d/01-pihole.conf
[i] Installing /etc/.pihole/advanced/06-rfc6761.conf...
[✓] Installed /etc/dnsmasq.d/06-rfc6761.conf
Existing DNS servers detected in setupVars.conf. Leaving them alone
::: Pre existing WEBPASSWORD found
DNSMasq binding to default interface: eth0
Added ENV to php:
"PHP_ERROR_LOG" => "/var/log/lighttpd/error.log",
"ServerIP" => "10.1.11.10",
"CORS_HOSTS" => "",
"VIRTUAL_HOST" => "pi.hole",
Using IPv4 and IPv6
::: Preexisting ad list /etc/pihole/adlists.list detected ((exiting setup_blocklists early))
sudo: unable to resolve host linuxbookpro: Name or service not known
::: Testing pihole-FTL DNS: FTL started!
::: Testing lighttpd config: Syntax OK
::: All config checks passed, cleared for startup ...
::: Enabling Query Logging
[i] Enabling logging...
[✓] Logging has been enabled!
::: Docker start setup complete
Checking if custom gravity.db is set in /etc/pihole/pihole-FTL.conf
Pi-hole version is v5.6 (Latest: v5.6)
AdminLTE version is v5.8 (Latest: v5.8)
FTL version is v5.11 (Latest: v5.11)
Container tag is: 2021.10.1
[cont-init.d] 20-start.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
Starting lighttpd
Starting crond
Starting pihole-FTL (no-daemon) as root
[services.d] done.
Stopping pihole-FTL
Thanks
