I'm trying to follow these instructions without success:
1 Google WiFi on 196.168.86.0/24 subnet, with IP 192.168.86.1
2 Pi is also on 192.168.86.0/24
3 Google WiFi has an IP reservation for the Pi, let's say 192.168.86.2
4 Google WiFi's IP pool range is a single address, that of the Pi
5 Google WiFi has Pi's IP as DNS server (and only that)
6 Pi's IP pool range does not overlap with Google WiFi's (in this example, 192.168.86.3 to whatever)
7 Pi has 192.168.86.1 configured as gateway
This list seems pretty straightforward. However, I think I have a configuration problem in the docker compose for pihole.
Instructions says:
- For DHCP it is recommended to remove these ports and instead add: network_mode: "host"
- 67:67/udp is required if you are using Pi-hole as your DHCP server
It seems these two instructions contradictory each other. Should I add network_mode: host and remove all ports, including port 67 - or should I keep port 67? Should this be done before step 1 above?
Thank you for clarification
