Pi-hole starts, but something in the startup process blocks it from running and being stable, so it restarts after every few seconds. It looks like a permissions issue but I don't know how to fix it.
No debug token available since pi-hole doesn't run long enough to connect to. Here's the log of the startup process (which repeats over and over if I let it):
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] 01-resolver-resolv: applying...
[fix-attrs.d] 01-resolver-resolv: exited 0.
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 20-start.sh: executing...
::: Starting docker specific checks & setup for docker pihole/pihole
WARNING Misconfigured DNS in /etc/resolv.conf: Two DNS servers are recommended, 127.0.0.1 and any backup server
WARNING Misconfigured DNS in /etc/resolv.conf: Primary DNS should be 127.0.0.1 (found 127.0.0.11)
nameserver 127.0.0.11
options ndots:0
[i] Existing PHP installation detected : PHP version 7.0.33-0+deb9u7
[i] Copying 01-pihole.conf to /etc/dnsmasq.d/01-pihole.conf...
[✓] Copying 01-pihole.conf to /etc/dnsmasq.d/01-pihole.conf
chown: cannot access '/etc/pihole/dhcp.leases': No such file or directory
::: Pre existing WEBPASSWORD found
Using default DNS servers: 8.8.8.8 & 8.8.4.4
DNSMasq binding to default interface: eth0
Added ENV to php:
"PHP_ERROR_LOG" => "/var/log/lighttpd/error.log",
"ServerIP" => "0.0.0.0",
"VIRTUAL_HOST" => "0.0.0.0",
Using IPv4 and IPv6
::: Preexisting ad list /etc/pihole/adlists.list detected ((exiting setup_blocklists early))
**sudo: unable to open /etc/sudoers: Permission denied**
**sudo: no valid sudoers sources found, quitting**
**sudo: unable to initialize policy plugin**
::: Testing pihole-FTL DNS: [cont-init.d] 20-start.sh: exited 1.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
I bolded the lines that I think are the problem. Any help would be appreciated. I've tried checking the ownership and permissions settings for docker and sudo and I far as I can tell they're configured correctly (I've followed the steps to add the docker group and give it sudo permissions).
FWIW I do have two other containers running without issue so far, so I'm not sure if this is a pi-hole misconfiguration or something with docker, but my instinct is with the former. I'm happy to share my docker-compose config if that helps, which is very lightly edited from here: GitHub - pi-hole/docker-pi-hole: Pi-hole in a docker container
I plan to configure pi-hole more extensively once I get it up and running properly.
The docker-compose.yml file is not on my main drive - I've been trying to get everything docker-related running from a slightly larger drive. It's on a drive I've labeled /media/drive1 (so the full directory is /media/drive1/docker-compose.yml)
Thanks, I saw that, but I'm not sure how to actually implement that solution (I'm not even sure exactly what the solution is). That user seemed to have a deeper understanding of permissions than I do. I'd be grateful for any additional information on what files/permissions to modify.
It would help to know what system is hosting your Docker Pi-hole.
Depending on that information, we or some other users may or may not be able to provide specific instructions (To be honest, I wouldn't have a clue if it would be OMV or Synology NAS or the likes).
If you are indeed runnning OMV as well, feel free to reply to that post I linked, and maybe @Vejv-cz can help you. I think other users would benefit as well if you were able to work out the details.
I haven't tried Ubuntu 20 yet, its on my list to upgrade, no other previous ubuntu have had permission
security issues out of the box but it isn't out of the question this is related to 20 somehow, maybe a new apparmour+docker issue or something.
Maybe strip down the docker run the just the bare basics and see if it also has the same error:
Good point, the snap was terrible the one time I tried it and I mentally blocked out that experience.
Make sure you use the official install only .. which now that I glance at it, doesn't say it supports 20.04 yet (It might work anyway with 19.10's instructions and a modified codename though - might need to find a stackoverflow/exchange on that topic)
I originally had docker installed with snap on 18.04. Ran into some issues, removed it, reinstalled using apt and the official install. That helped get a much smoother experience with my other containers (but I hadn't yet tried running pi-hole). Then, wanting to work on the latest LTS release, I updated the OS to 20.04.
Now that I think of it, there was a message about docker not having an image for the 20.04 release yet. I'll keep an eye out for that, and hopefully it'll clear up the issue-and if it does, I'll be sure to come back and post an update. Thank you all for your help!
