Docker pi-hole admin page showing "lost connection to API" after upgrade to ubuntu 18.04
admin dashboard should load correctly
dashboard shows "lost connection to API"
4jzrp6h80w
This thread has the info you should need
Hey,
Thanks for checking but I don't think that's the issue - systemd-resolved was already disabled before I upgraded the Ubuntu version. This is how it looks now:
root@teevee:~# systemctl status systemd-resolved
ā— systemd-resolved.service - Network Name Resolution
Loaded: loaded (/lib/systemd/system/systemd-resolved.service; disabled; vendor preset: enabled)
Active: inactive (dead)
Docs: man:systemd-resolved.service(8)
https://www.freedesktop.org/wiki/Software/systemd/resolved
https://www.freedesktop.org/wiki/Software/systemd/writing-network-configuration-managers
https://www.freedesktop.org/wiki/Software/systemd/writing-resolver-clients
And nothing is listening on port 53:
root@teevee:~# netstat -anp | grep 53 | grep -i listen
tcp6 0 0 :::53 :::* LISTEN 10095/docker-proxy
and I can see queries in the pihole.log
To add to the original error report (something I should have put in there originally, but oh well) - I had to start lighttpd manually via /etc/init.d/lighttpd start, it did not start automatically
something is using 53 unless that is your dockerized instance
please try from within your container sudo service pihole-FTL start
Ah, it turns out your first reply was on-point :slight_smile: i implemented exactly what the article said, and now pihole works perfectly. Thanks very much for your help!
For future visitors: in Ubuntu 18.04, simply disabling systemd-resolved is not sufficient, please implement the steps in the link provided by technicalpyro
