Docker fails to start due to iproute is not available
I have an issue with this latest update. Fails to start in docker because iproute is not available but iproute2 is and is already installed. Then of course it terminates the processes. Running raspberry os 64-bit. Linux pi 5.10.4-v8+ #1389 SMP PREEMPT Wed Jan 6 13:52:18 GMT 2021 aarch64 GNU/Linux
I am also having this problem. I am running the docker container and when it updated I started seeing this. I deleted the container and re-created it with the same docker-compose script I used for the initial install.
https://github.com/pi-hole/docker-pi-hole/issues/762
Adding 8.8.8.8 and removing 127.0.0.1 from the DNS servers in the docker-compose script fixed this. Thanks for the help!
