I am trying to use this setup and I can see dhcp requests being received in the dhcphelper container but they are not being received at the pihole container.
Any pointers?
Any pointers?
Can you share your docker run or docker-compose for both containers?
Have you enabled DHCP in Pi-hole's settings?
Yes, I have enabled DHCP. My reply was to a separate thread and I didn't mean to start a new thread. My response without context won't be very productive.
I moved it to a new thread as it's a new help request. The old thread is linked for context.
Anyways I managed to get it running by using ISC DHCP relay instead of dhcp-helper.
dhcrelay/Dockerfile
FROM debian:buster-slim
RUN apt-get update
RUN apt-get install -y isc-dhcp-relay
EXPOSE 67 67/udp
ENTRYPOINT ["dhcrelay", "-d"]
docker-compose.yml
version: "3"
services:
pihole:
image: pihole/pihole:latest
ports:
- "53:53/tcp"
- "53:53/udp"
- "80:80/tcp"
environment:
ServerIP: x.x.x.x
TZ: 'Asia/Karachi'
DNS1: 1.1.1.1
DNS2: 1.0.0.1
DNSMASQ_LISTENING: all
WEBPASSWORD: xyz
volumes:
- './pihole/:/etc/pihole/'
- './dnsmasq/:/etc/dnsmasq.d/'
dns:
- 127.0.0.1
cap_add:
- NET_ADMIN
restart: always
networks:
default:
ipv4_address: 10.0.0.10
dhcrelay:
build: ./dhcrelay
restart: always
network_mode: host
command: ["-id", "eno1", "-iu", "br-pihole", "10.0.0.10"]
cap_add:
- NET_ADMIN
networks:
default:
driver: bridge
driver_opts:
com.docker.network.bridge.name: br-pihole
ipam:
config:
- subnet: 10.0.0.0/24
