since today, I'm not able to start Pi-Hole in a Docker Container anymore. It crashes without any error like so:
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service cron: starting
s6-rc: info: service cron successfully started
s6-rc: info: service _uid-gid-changer: starting
s6-rc: info: service _uid-gid-changer successfully started
s6-rc: info: service _startup: starting
[i] Starting docker specific checks & setup for docker pihole/pihole
[i] Setting capabilities on pihole-FTL where possible
[i] Applying the following caps to pihole-FTL:
* CAP_CHOWN
* CAP_NET_BIND_SERVICE
* CAP_NET_RAW
[i] Ensuring basic configuration by re-running select functions from basic-install.sh
[i] Installing /etc/dnsmasq.d/01-pihole.conf...
[✓] Installed /etc/dnsmasq.d/01-pihole.conf
[i] Installing /etc/.pihole/advanced/06-rfc6761.conf...
[✓] Installed /etc/dnsmasq.d/06-rfc6761.conf
[i] Installing latest logrotate script...
[✓] Installing latest logrotate script
[i] Creating empty /etc/pihole/setupVars.conf file.
[i] Assigning password defined by Environment Variable
[✓] New password set
[i] Added ENV to php:
"TZ" => "Europe/Berlin",
"PIHOLE_DOCKER_TAG" => "",
"PHP_ERROR_LOG" => "/var/log/lighttpd/error-pihole.log",
"CORS_HOSTS" => "",
"VIRTUAL_HOST" => "5cf02c43d338",
[i] Using IPv4 and IPv6
[i] Installing latest Cron script...
[✓] Installing latest Cron script
[i] setup_blocklists now setting default blocklists up:
[i] TIP: Use a docker volume for /etc/pihole/adlists.list if you want to customize for first boot
[i] Blocklists (/etc/pihole/adlists.list) now set to:
[i] Setting DNS servers based on PIHOLE_DNS_ variable
[i] Applying pihole-FTL.conf setting LOCAL_IPV4=0.0.0.0
[i] FTL binding to default interface: eth0
[i] Enabling Query Logging
[i] Testing lighttpd config: Syntax OK
[i] All config checks passed, cleared for startup ...
[i] Docker start setup complete
[i] pihole-FTL (no-daemon) will be started as pihole
s6-rc: info: service _startup successfully started
s6-rc: info: service pihole-FTL: starting
s6-rc: info: service pihole-FTL successfully started
s6-rc: info: service lighttpd: starting
s6-rc: info: service lighttpd successfully started
s6-rc: info: service _postFTL: starting
s6-rc: info: service _postFTL successfully started
s6-rc: info: service legacy-services: starting
Checking if custom gravity.db is set in /etc/pihole/pihole-FTL.conf
s6-rc: info: service legacy-services successfully started
[i] Creating new gravity database
[i] Migrating content of /etc/pihole/adlists.list into new database
[i] Preparing new gravity database...
[i] Creating new gravity databases...
[✓] Creating new gravity databases
[i] Libz compression not available
[i] Status: Pending...
[✗] Status: https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts ()
[✗] List download failed: no cached list available
[i] Building tree...
[✓] Building tree
[i] Swapping databases...
[✓] Swapping databases
[✓] The old database remains available
[i] Number of gravity domains: 0 (0 unique domains)
[i] Number of exact blacklisted domains: 0
[i] Number of regex blacklist filters: 0
[i] Number of exact whitelisted domains: 0
[i] Number of regex whitelist filters: 0
[i] Cleaning up stray matter...
[✓] Cleaning up stray matter
[✓] FTL is listening on port 53
[✓] UDP (IPv4)
[✓] TCP (IPv4)
[✓] UDP (IPv6)
[✓] TCP (IPv6)
[i] Pi-hole blocking will be enabled
[i] Enabling blocking
[✓] Pi-hole Enabled
fatal:
fatal:
fatal:
Pi-hole version is v5.17.1 (Latest: N/A)
AdminLTE version is v5.20.1 (Latest: N/A)
FTL version is v5.23 (Latest: N/A)
Container tag is: 2023.05.2
I also tried to start from scratch with deleting the bind mounts, but no luck.
That's my compose file (Actually I'm using Portainer)
services:
pihole_neu:
container_name: "pihole_neu"
environment:
- "WEBPASSWORD=RQDQ6fVB"
- "PIHOLE_DNS_=208.67.222.222;208.67.220.220"
- "TZ=Europe/Berlin"
- "PATH=/opt/pihole:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin"
- "IPv6=True"
- "DNSMASQ_USER=pihole"
- "phpver=php"
- "PHP_ERROR_LOG=/var/log/lighttpd/error-pihole.log"
- "S6_KEEP_ENV=1"
- "S6_BEHAVIOUR_IF_STAGE2_FAILS=2"
- "S6_CMD_WAIT_FOR_SERVICES_MAXTIME=0"
- "FTLCONF_LOCAL_IPV4=0.0.0.0"
- "FTL_CMD=no-daemon"
hostname: "5cf02c43d338"
image: "pihole/pihole:latest"
mac_address: "02:42:ac:11:00:06"
network_mode: "bridge"
ports:
- "53:53/tcp"
- "53:53/udp"
- "8053:80/tcp"
restart: "always"
volumes:
- "/opt/docker/pihole/etc/dnsmasq.d:/etc/dnsmasq.d"
- "/opt/docker/pihole/etc/pihole:/etc/pihole"
cap_drop:
- "AUDIT_CONTROL"
- "BLOCK_SUSPEND"
- "DAC_READ_SEARCH"
- "IPC_LOCK"
- "IPC_OWNER"
- "LEASE"
- "LINUX_IMMUTABLE"
- "MAC_ADMIN"
- "MAC_OVERRIDE"
- "NET_BROADCAST"
- "SYSLOG"
- "SYS_ADMIN"
- "SYS_BOOT"
- "SYS_MODULE"
- "SYS_NICE"
- "SYS_PACCT"
- "SYS_PTRACE"
- "SYS_RAWIO"
- "SYS_RESOURCE"
- "SYS_TIME"
- "SYS_TTY_CONFIG"
- "WAKE_ALARM"
version: "3.6"
