Do not work with VLANS?
I have Unifi dream machine setup with 4 networks.
Main:
"Pagrindinis" / 192.168.1.0/24
Virtual:
"Svečiams" / VLAN 2 / 192.168.2.0/24
"IoT" / VLAN 3 / 192.168.3.0/24
"IoT be interneto" / VLAN 4 / 192.168.4.0/24
There are no firewall rules applied - inter VLAN devices can ping each other.
Pihole is in 192.168.1.0/24 with IP 192.168.1.53
Devices in all networks get 192.168.1.53 as DNS server set via DHCP.
In pihole there's local record:
Domain: nas.8-2.bijunu.lt
IP: 192.168.1.188
Both the DNS blocking and local DNS records should be working for all the networks through single pihole at 192.168.1.53.
DNS blocking and local DNS records work only on 192.168.1.0/24 .
Here are nslookups:
From 192.168.1.0/24:
nslookup pi.hole         ✔
Server:		192.168.1.53
Address:	192.168.1.53#53
Address: fe80::3257:9126:8316:6949
nslookup nas.8-2.bijunu.lt         ✔
Address: 192.168.1.188
And here's from 192.168.3.0/24:
** server can't find pi.hole: NXDOMAIN
nslookup nas.8-2.bijunu.lt         1 ✘
** server can't find nas.8-2.bijunu.lt: NXDOMAIN
cat /etc/resolv.conf         1 ✘
# Generated by NetworkManager
nameserver 192.168.1.53
Looks as if pihole is not even responding to those queries. What should I debug/do next?
https://tricorder.pi-hole.net/anneb9Wa/
Run from a 192.168.3.0/24 machine, what's the output of:
nslookup -class=chaos -type=txt version.bind
nslookup -class=chaos -type=txt version.bind         ✔
version.bind	text = "dnsmasq-2.86"
It is definitely not Pi-hole answering those requests.
The expected outcome should have looked similar to dnsmasq-pi-hole-v2.xx-xxxxx.
Combined with your own nslookup results, that would indicate that your router is intercepting DNS requests from your VLANs and redirecting them to its own DNS resolver (or -less likely- an additional dnsmasq may run on your Pi-hole machine - your debug log shows no signs of a dnsmasq process, though).
You'd have to consult your router for details of its VLAN DNS configuration.
thank you, I'll ask ubiquity support in the meantime
Looks like I've found the issue... Ubiquity sneakily introduced new option for DNS blocking in network settings. Once I've disabled that - DNS resolution via pihole started to work :slight_smile:
