I can only see other docker services in logged, like service.pihole.
Devices from DHCP are not recognized (they all fall to 192.168.4.1, docker's internal network gateway).
Is there a way to fix this? I think it was working before last update?
Thank you.
Please follow at least the template
[Replace this text with what you think should be happening. Please include as much detail as possible including, but not limited to:
-operating system
-hardware]
The expected behaviour is having the devices using the DHCP service properly recognized and logged in the query log.
Acutally, only other docker services get properly recognized (service.pihole) and logged, while all of the DHCP devices get logged as the gateway IP of the intenal docker network (192.168.4.1)
https://tricorder.pi-hole.net/oOMp0WMz/
Please, also post your compose file or docker run command used to start the container.
services:
pihole:
container_name: pihole
domainname: docker
hostname: pihole
image: pihole/pihole:latest
pull_policy: always
restart: unless-stopped
ports:
- "53:53/tcp"
- "53:53/udp"
cap_add:
- NET_ADMIN
dns:
- 127.0.0.1
environment:
- ServerIP=${SERVER_IP}
- PROXY_LOCATION="pihole"
- VIRTUAL_HOST=pihole.${DOMAINNAME_1}
- VIRTUAL_PORT=80
- TZ=${TZ}
- WEBPASSWORD=piholeadmin
- DNS1=192.168.4.101#5054
- IPv6=false
- DNS2=""
- DNSMASQ_LISTENING=all
volumes:
- '$CONFIGDIR/pihole/pihole/:/etc/pihole/'
- '$CONFIGDIR/pihole/dnsmasq.d/:/etc/dnsmasq.d/'
depends_on:
- dhcphelper
networks:
traefik:
ipv4_address: '192.168.3.100'
pihole:
ipv4_address: '192.168.4.100'
labels:
- "org.label-schema.group=monitoring"
- "traefik.enable=true"
# HTTP Routers
- "traefik.http.routers.pihole-rtr.entrypoints=websecure"
- "traefik.http.routers.pihole-rtr.rule=Host(`pihole.$DOMAINNAME_1`)" # HostRegexp:pihole.${DOMAINNAME_1},{catchall:.*}" # Host(`pihole.$DOMAINNAME_1`)"
# Middlewares
- "traefik.http.routers.pihole-rtr.middlewares=middlewares-chain-no-auth@file"
# HTTP Services
- "traefik.http.routers.pihole-rtr.service=pihole-svc"
- "traefik.http.services.pihole-svc.loadbalancer.server.port=80"
You have networks declared inside your services, but you need to declare your networks in the yml file like this:
services:
pihole:
networks:
networks:
https://docs.docker.com/compose/networking/#specify-custom-networks
Sorry, I only posted the pihole service yaml, here's the complete docker-compose, containing the networks:
version: "3.9"
# NETWORKS
networks:
traefik:
external: true
pihole:
external: true
monitoring:
external: true
# dnet:
# external: true
# SECRETS
secrets:
cf_dns_api_token:
file: $SECRETSDIR/cf_dns_api_token
# SERVICES
include:
# NETWORK
# Traefik 2 - Reverse Proxy
- compose/network/traefik.yaml
#Cloudflared DNS DoH
- compose/network/cloudflared.yaml
#Pihole DNS DHCP server
- compose/network/pihole.yaml
Is there anything I can do to fix/debug it?
Hi @rdwebdesign
Is there anything I can do to properly understand/debug/fix the situation?
It's also worth noting that I am not seeing any blocked query since some days, while I had mostly 10% blocked before. No configuration change worth mentioning on my side.
I'm keeping pihole up to date.
I'm seeing all of the DHCP devices stopped querying as themselves on a precise date, and now they all query as the docker's network gateway:
It seems something happened, probably I triggered a configuration or something?
I have a configuration made following this guide (DHCP with docker-compose and bridge networking), not working (still seeing only one IP for all DHCP devices, probably something wrong)
services:
dhcphelper:
container_name: dhcp-helper
build: ./dhcp-helper
network_mode: "host"
command: -s 192.168.4.100
cap_add:
- NET_ADMIN
labels:
pihole:
domainname: docker
hostname: pihole
pull_policy: always
# security_opt:
# - no-new-privileges:true
# profiles: ["core", "all"]
# networks:
# - dnet
# - traefik
ports:
- "53:53/tcp"
- "53:53/udp"
# - "67:67/udp"
# - "8081:80"
cap_add:
- NET_ADMIN
dns:
- 127.0.0.1
environment:
# - PUID=${PUID}
# - GUID=${GUID}
- VIRTUAL_PORT=80
- TZ=${TZ}
- WEBPASSWORD=<password>
- IPv6=false
- DNS2=""
volumes:
depends_on:
- dhcphelper
networks:
traefik:
pihole:
labels:
# HTTP Routers
# Middlewares
# HTTP Services
docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
138e2a9acedb pihole/pihole:latest "/s6-init" 28 minutes ago Up 28 minutes (healthy) 0.0.0.0:53->53/tcp, 0.0.0.0:53->53/udp, 67/udp, 80/tcp pihole
a45e00f0907f docker-compose-dhcphelper "dhcp-helper -n -s 1…" 2 weeks ago Up 2 weeks dhcp-helper
sudo netstat -tulpn
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 0.0.0.0:53 0.0.0.0:* LISTEN 19119/docker-proxy
udp 0 0 0.0.0.0:53 0.0.0.0:* 19134/docker-proxy
udp 0 0 0.0.0.0:67 0.0.0.0:* 3306/dhcp-helper
