Under the Settings page -> DNS tab, I checked DNSSEC. After checking, all devices, other than raspberry pi were unable to use internet and after rebooting pi and devices, cannot connect to network. I unchecked the DNSSEC check box but problem still persists.
I found this reddit post "Help, DNSSEC broke my Pihole" which also describes the same issue, but this person never submitted a debug log.
All I did was click DNSSEC to test it out. On breaking the network, I immediately unchecked and began troubleshooting, but it was too late. I did not find other instances on this discourse of this issue.
You have some problems shown in your debug log, unrelated to DNSSEC. This is likely why no other device other than the Pi can get DNS resolution.
[✓] IPv4 address(es) bound to the tun0 interface:
10.8.0.1/24 does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
[✓] IPv6 address(es) bound to the tun0 interface:
fe80::c079:fbf8:bac6:51b4 does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
* Pinging 192.168.1.1...
[✓] www.radioescapades.org is 0.0.0.0 via localhost (127.0.0.1)
[✗] Failed to resolve www.radioescapades.org via Pi-hole (192.168.1.216)
[✓] doubleclick.com is 172.217.9.206 via a remote, public DNS server (8.8.8.8)
Thanks for the help, but I had to start over. I made an attempt to fix the mismatch in setupVars.conf and that did not help. Additionally, now that my new setup is up and running, a debug log reveals the same info under Networking (i.e., IPv4 addresses do not match and gateway did not respond), so that probably wasn't contributing. I will just leave DNSSEC unchecked. Again, many thanks jfb!
