Hi, I just installed pihole using the bash basic-install.sh method. I'm running a centos 7 minimal install as the OS.
sudo pihole status
::: DNS service is NOT running
sudo systemctl status dnsmasq
● dnsmasq.service - DNS caching server.
Loaded: loaded (/usr/lib/systemd/system/dnsmasq.service; enabled; vendor preset: disabled)
Active: failed (Result: exit-code) since Wed 2017-08-09 00:24:04 PDT; 4min 41s ago
Process: 7814 ExecStart=/usr/sbin/dnsmasq -k (code=exited, status=3)
Main PID: 7814 (code=exited, status=3)
Aug 09 00:24:04 dt-pihole.tang.local systemd[1]: Started DNS caching server..
Aug 09 00:24:04 dt-pihole.tang.local systemd[1]: Starting DNS caching server....
Aug 09 00:24:04 dt-pihole.tang.local dnsmasq[7814]: dnsmasq: cannot open log /var/log/pihole.log: Permission denied
Aug 09 00:24:04 dt-pihole.tang.local systemd[1]: dnsmasq.service: main process exited, code=exited, status=3/NOTIMPLEMENTED
Aug 09 00:24:04 dt-pihole.tang.local systemd[1]: Unit dnsmasq.service entered failed state.
Aug 09 00:24:04 dt-pihole.tang.local systemd[1]: dnsmasq.service failed.
seems like dnsmasq isn't running at all. Thanks in advance for the help!
Just restarted and it seems to have stuck. Dnsmasq started just fine but now i can't browse to http:///admin. Would you like me to make another post for that?
