I am continually getting a Warning in dnsmasq core: stating:-
'not giving name raspberrypi.lan to the DHCP lease of 192.168.1.86 because the name exists in /etc/hosts with address 127.0.1.1'
I just have pihole on a pi, This warning never causes any problem because pihole still works well but I keep deleting the warning and it just comes back again.
There must be an option in the settings or tools to stop this warning but I can't work out what it is.
If anyone has an idea on how to stop this warning I'd love to know.
You should change the name in either of the two locations.
not giving name HOSTNAME to the DHCP lease of ADDRESS because the name exists in SOURCE with address CACHE_ADDR
If HOSTNAME is known through a HOSTS file or config (see SOURCE) and the DHCP address ADDRESS does not match the address in the cache (CACHE_ADDR), dnsmasq prevents giving the name to a DHCP client. This prevents possible hostname hijacking by malicious devices.
If those messages weren't triggered by you creating a Pi-hole debug log, this could indicate that you run your Pi-hole as DHCP server, while its OS is still acquiring its IP address via DHCP.
Instead, you should configure the Pi-hole machine for a static IP if Pi-hole runs as DHCP server.
