I just got started and I am loving this project. It works great.
I just have 1 problem, whenever I want to restart dnsmasq(through the admin gui), it seems to just hang., it just seems to timeout., then a few minutes later I can try again and it works fine.
I am stumped by what's going on.
I am on Ubuntu 14.04.1 LTS. I see the following messages in syslog which may be of some relevance here.
Apr 30 11:51:49 storage systemd[1]: dnsmasq.service: Start-post operation timed out. Stopping.
Apr 30 11:51:49 storage systemd[1]: Failed to start dnsmasq - A lightweight DHCP and caching DNS server.
Apr 30 11:51:49 storage systemd[1]: Dependency failed for Host and Network Name Lookups.
Apr 30 11:51:49 storage systemd[1]: nss-lookup.target: Job nss-lookup.target/start failed with result 'dependency'.
Apr 30 11:51:49 storage systemd[1]: dnsmasq.service: Unit entered failed state.
Apr 30 11:51:49 storage systemd[1]: dnsmasq.service: Failed with result 'timeout'.
It does respond and it is working, just when I use systemctl to restart it hangs. Right now it is running fine.
● dnsmasq.service - dnsmasq - A lightweight DHCP and caching DNS server
Loaded: loaded (/lib/systemd/system/dnsmasq.service; enabled; vendor preset: enabled)
Drop-In: /run/systemd/generator/dnsmasq.service.d
└─50-dnsmasq-$named.conf, 50-insserv.conf-$named.conf
Active: active (running) since Sun 2017-04-30 11:55:00 EDT; 1h 6min ago
Process: 5939 ExecStop=/etc/init.d/dnsmasq systemd-stop-resolvconf (code=exited, status=0/SUCCESS)
Process: 6750 ExecStartPost=/etc/init.d/dnsmasq systemd-start-resolvconf (code=exited, status=0/SUCCESS)
Process: 6742 ExecStart=/etc/init.d/dnsmasq systemd-exec (code=exited, status=0/SUCCESS)
Process: 6738 ExecStartPre=/usr/sbin/dnsmasq --test (code=exited, status=0/SUCCESS)
Main PID: 6749 (dnsmasq)
Tasks: 1
Memory: 15.7M
CPU: 465ms
CGroup: /system.slice/dnsmasq.service
└─6749 /usr/sbin/dnsmasq -x /var/run/dnsmasq/dnsmasq.pid -u dnsmasq -r /var/run/dnsmasq/resolv.conf -7 /etc/dnsmasq.d,.dpkg-dist,.dpkg-old,.dpkg-new --loc
Apr 30 11:55:00 storage systemd[1]: Starting dnsmasq - A lightweight DHCP and caching DNS server...
Apr 30 11:55:00 storage dnsmasq[6738]: dnsmasq: syntax check OK.
Apr 30 11:55:00 storage systemd[1]: Started dnsmasq - A lightweight DHCP and caching DNS server.
host -a pi.hole localhost
Tasks: 1
Memory: 15.7M
CPU: 465ms
To add some more color to this issue, unfortunately I still keep running into it. I debugged it a bit further and this is what I find. Whenever I reload pihole, the script issues a systemctl dnsmasq restart. Going a few levels below, the final step is the issuing the following 2 commands.
When these commands are being issued, the script hangs and times out. I
##Stop
/sbin/resolvconf -d lo.dnsmasq
Startup
echo "nameserver 127.0.0.1" | /sbin/resolvconf -a lo.dnsmasq
One of these days I will figure out the issue. If anybody has any thoughts, please share away.
It specifically hangs in the 2 commands. I can't consistently recreate the same scenario, if the script hangs, I just stop it again & restart and it works.
Dont know but sounds like some parts were not configured properly during setup or you yourself configured something wrong somewhere.
Can you post the resulting log at "/var/log/pihole_debug.log" after running below command ?
Dont upload the log yet when asked!
You might be asked to upload it later by one of the Pi-Hole folks.
And post content of "/etc/pihole/install.log" too please ?
Ps. post the long results in between code tags or else this thread will become unreadable!
pi@noads:~ $ apt-cache depends systemd | awk '{print $2}' | strings | dpkg -l
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Architecture Description
ii acl 2.2.52-2 armhf Access control list utilities
ii adduser 3.113+nmu3 all add and remove users and groups
ii alsa-utils 1.0.28-1 armhf Utilities for configuring and using ALSA
ii apt 1.0.9.8.4 armhf commandline package manager
ii apt-listchanges 2.85.13+nmu1 all package change history notification tool
ii apt-utils 1.0.9.8.4 armhf package management related utility programs
ii aptitude 0.6.11-1 armhf terminal-based package manager
ii aptitude-common 0.6.11-1 all architecture independent files for the aptitude package manager
ii avahi-daemon 0.6.31-5 armhf Avahi mDNS/DNS-SD daemon
ii base-files 8+rpi1 armhf Debian base system miscellaneous files
ii base-passwd 3.5.37 armhf Debian base system master password and group files
ii bash 4.3-11+deb8u1 armhf GNU Bourne Again SHell
ii bash-completion 1:2.1-4 all programmable completion for the bash shell
ii bc 1.06.95-9 armhf GNU bc arbitrary precision calculator language
ii bind9-host 1:9.9.5.dfsg-9+deb8u10 armhf Version of 'host' bundled with BIND 9.X
ii binutils 2.25-5 armhf GNU assembler, linker and binary utilities
ii bluez 5.23-2+rpi2 armhf Bluetooth tools and daemons
ii bluez-firmware 1.2-3+rpi1 all Firmware for Bluetooth devices
ii bsdmainutils 9.0.6 armhf collection of more utilities from FreeBSD
ii bsdutils 1:2.25.2-6 armhf basic utilities from 4.4BSD-Lite
ii build-essential 11.7 armhf Informational list of build-essential packages
ii bzip2 1.0.6-7 armhf high-quality block-sorting file compressor - utilities
ii ca-certificates 20141019+deb8u2 all Common CA certificates
ii cifs-utils 2:6.4-1 armhf Common Internet File System utilities
ii console-setup 1.123 all console font and keymap setup program
ii console-setup-linux 1.123 all Linux specific part of console-setup
ii coreutils 8.23-4 armhf GNU core utilities
ii cpio 2.11+dfsg-4.1+deb8u1 armhf GNU cpio -- a program to manage archives of files
ii cpp 4:4.9.2-2 armhf GNU C preprocessor (cpp)
ii cpp-4.9 4.9.2-10 armhf GNU C preprocessor
ii crda 3.13-1 armhf wireless Central Regulatory Domain Agent
ii cron 3.0pl1-127+deb8u1 armhf process scheduling daemon
ii curl 7.38.0-4+deb8u5 armhf command line tool for transferring data with URL syntax
ii dash 0.5.7-4 armhf POSIX-compliant shell
ii dbus 1.8.22-0+deb8u1 armhf simple interprocess messaging system (daemon and utilities)
ii dc 1.06.95-9 armhf GNU dc arbitrary precision reverse-polish calculator
ii debconf 1.5.56 all Debian configuration management system
ii debconf-i18n 1.5.56 all full internationalization support for debconf
ii debconf-utils 1.5.56 all debconf utilities
ii debianutils 4.4 armhf Miscellaneous utilities specific to Debian
ii device-tree-compiler 1.4.1-1+rpi1 armhf Device Tree Compiler for Flat Device Trees
ii dhcpcd5 6.7.1-1+rpi5 armhf DHCPv4, IPv6RA and DHCPv6 client with IPv4LL support
ii dialog 1.2-20140911-1 armhf Displays user-friendly dialog boxes from shell scripts
ii diffutils 1:3.3-1 armhf File comparison utilities
ii dmidecode 2.12-3 armhf SMBIOS/DMI table decoder
ii dmsetup 2:1.02.90-2.2+deb8u1 armhf Linux Kernel Device Mapper userspace library
ii dnsmasq 2.76-5+rpi1 all Small caching DNS proxy and DHCP/TFTP server
ii dnsmasq-base 2.76-5+rpi1 armhf Small caching DNS proxy and DHCP/TFTP server
ii dnsutils 1:9.9.5.dfsg-9+deb8u10 armhf Clients provided with BIND
ii dosfstools 3.0.27-1 armhf utilities for making and checking MS-DOS FAT filesystems
ii dphys-swapfile 20100506-1 all Autogenerate and use a swap file
ii dpkg 1.17.27 armhf Debian package management system
ii dpkg-dev 1.17.27 all Debian package development tools
ii e2fslibs:armhf 1.42.12-2 armhf ext2/ext3/ext4 file system libraries
ii e2fsprogs 1.42.12-2 armhf ext2/ext3/ext4 file system utilities
ii ed 1.10-2 armhf classic UNIX line editor
ii fake-hwclock 0.9 all Save/restore system clock on machines without working RTC hardware
ii fakeroot 1.20.2-1 armhf tool for simulating superuser privileges
ii fbset 2.1-28 armhf framebuffer device maintenance program
ii file 1:5.22+15-2+deb8u3 armhf Determines file type using "magic" numbers
ii findutils 4.4.2-9 armhf utilities for finding files--find, xargs
ii firmware-atheros 0.43+rpi5 all Binary firmware for Atheros wireless cards
ii firmware-brcm80211 0.43+rpi5 all Binary firmware for Broadcom 802.11 wireless cards
ii firmware-libertas 0.43+rpi5 all Binary firmware for Marvell Libertas 8xxx wireless cards
ii firmware-ralink 0.43+rpi5 all Binary firmware for Ralink wireless cards
ii firmware-realtek 0.43+rpi5 all Binary firmware for Realtek wired and wireless network adapters
ii ftp 0.17-31 armhf classical file transfer client
ii g++ 4:4.9.2-2 armhf GNU C++ compiler
ii g++-4.9 4.9.2-10 armhf GNU C++ compiler
ii gcc 4:4.9.2-2 armhf GNU C compiler
ii gcc-4.6-base:armhf 4.6.4-5+rpi1 armhf GCC, the GNU Compiler Collection (base package)
ii gcc-4.7-base:armhf 4.7.3-11+rpi1 armhf GCC, the GNU Compiler Collection (base package)
ii gcc-4.8-base:armhf 4.8.4-1 armhf GCC, the GNU Compiler Collection (base package)
ii gcc-4.9 4.9.2-10 armhf GNU C compiler
ii gcc-4.9-base:armhf 4.9.2-10 armhf GCC, the GNU Compiler Collection (base package)
ii gdb 7.7.1+dfsg-5+rpi1 armhf GNU Debugger
ii gdbserver 7.7.1+dfsg-5+rpi1 armhf GNU Debugger (remote server)
ii geoip-database 20150317-1 all IP lookup command line tools that use the GeoIP library (country database)
ii git 1:2.1.4-2.1+deb8u2 armhf fast, scalable, distributed revision control system
ii git-man 1:2.1.4-2.1+deb8u2 all fast, scalable, distributed revision control system (manual pages)
ii gnupg 1.4.18-7+deb8u3 armhf GNU privacy guard - a free PGP replacement
ii gpgv 1.4.18-7+deb8u3 armhf GNU privacy guard - signature verification tool
ii grep 2.20-4.1 armhf GNU grep, egrep and fgrep
ii groff-base 1.22.2-8 armhf GNU troff text-formatting system (base system components)
ii gzip 1.6-4 armhf GNU compression utilities
ii hardlink 0.3.0 armhf Hardlinks multiple copies of the same file
ii hostname 3.15 armhf utility to set/show the host name or domain name
ii ifupdown 0.7.53.1 armhf high level tools to configure network interfaces
ii info 5.2.0.dfsg.1-6 armhf Standalone GNU Info documentation browser
ii init 1.22 armhf System-V-like init utilities - metapackage
ii init-system-helpers 1.22 all helper tools for all init systems
ii initramfs-tools 0.120+deb8u2 all generic modular initramfs generator
ii initscripts 2.88dsf-59 armhf scripts for initializing and shutting down the system
ii insserv 1.14.0-5 armhf boot sequence organizer using LSB init.d script dependency information
ii install-info 5.2.0.dfsg.1-6 armhf Manage installed documentation in info format
ii iproute2 3.16.0-2 armhf networking and traffic control tools
ii iptables 1.4.21-2 armhf administration tools for packet filtering and NAT
ii iputils-ping 3:20121221-5 armhf Tools to test the reachability of network hosts
ii isc-dhcp-client 4.3.1-6+deb8u2 armhf DHCP client for automatically obtaining an IP address
ii isc-dhcp-common 4.3.1-6+deb8u2 armhf common files used by all of the isc-dhcp packages
ii iso-codes 3.57-1 all ISO language, territory, currency, script codes and their translations
ii iw 3.17-1 armhf tool for configuring Linux wireless devices
ii kbd 1.15.5-2 armhf Linux console font and keytable utilities
ii keyboard-configuration 1.123 all system-wide keyboard preferences
ii klibc-utils 2.0.4-2+rpi1 armhf small utilities built with klibc for early boot
ii kmod 18-3 armhf tools for managing Linux kernel modules
ii less 458-3 armhf pager program similar to more
ii libacl1:armhf 2.2.52-2 armhf Access control list shared library
ii libalgorithm-c3-perl 0.09-1 all Perl module for merging hierarchies using the C3 algorithm
ii libalgorithm-diff-perl 1.19.02-3 all module to find differences between files
ii libalgorithm-diff-xs-perl 0.04-3+b1 armhf module to find differences between files (XS accelerated)
ii libalgorithm-merge-perl 0.08-2 all Perl module for three-way merge of textual data
ii libapt-inst1.5:armhf 1.0.9.8.4 armhf deb package format runtime library
ii libapt-pkg4.12:armhf 1.0.9.8.4 armhf package management runtime library
ii libarchive-extract-perl 0.72-1 all generic archive extracting module
ii libasan1:armhf 4.9.2-10 armhf AddressSanitizer -- a fast memory error detector
ii libasound2:armhf 1.0.28-1+rpi2 armhf shared library for ALSA applications
ii libasound2-data 1.0.28-1+rpi2 all Configuration files and profiles for ALSA drivers
ii libatomic1:armhf 4.9.2-10 armhf support library providing __atomic built-in functions
ii libattr1:armhf 1:2.4.47-2 armhf Extended attribute shared library
ii libaudit-common 1:2.4-1 all Dynamic library for security auditing - common files
ii libaudit1:armhf 1:2.4-1 armhf Dynamic library for security auditing
ii libavahi-common-data:armhf 0.6.31-5 armhf Avahi common data files
ii libavahi-common3:armhf 0.6.31-5 armhf Avahi common library
ii libavahi-core7:armhf 0.6.31-5 armhf Avahi's embeddable mDNS/DNS-SD library
ii libbind9-90 1:9.9.5.dfsg-9+deb8u10 armhf BIND9 Shared Library used by BIND
ii libblkid1:armhf 2.25.2-6 armhf block device id library
ii libboost-iostreams1.49.0 1.49.0-4+b2 armhf Boost.Iostreams Library
ii libboost-iostreams1.50.0 1.50.0-1+b2 armhf Boost.Iostreams Library
ii libboost-iostreams1.53.0 1.53.0-6+b2 armhf Boost.Iostreams Library
ii libboost-iostreams1.54.0:armhf 1.54.0-5 armhf Boost.Iostreams Library
ii libboost-iostreams1.55.0:armhf 1.55.0+dfsg-3 armhf Boost.Iostreams Library
ii libbsd0:armhf 0.7.0-2 armhf utility functions from BSD systems - shared library
ii libbz2-1.0:armhf 1.0.6-7 armhf high-quality block-sorting file compressor library - runtime
ii libc-bin 2.19-18+deb8u7 armhf GNU C Library: Binaries
ii libc-dev-bin 2.19-18+deb8u7 armhf GNU C Library: Development binaries
ii libc6:armhf 2.19-18+deb8u7 armhf GNU C Library: Shared libraries
ii libc6-dbg:armhf 2.19-18+deb8u7 armhf GNU C Library: detached debugging symbols
ii libc6-dev:armhf 2.19-18+deb8u7 armhf GNU C Library: Development Libraries and Header Files
ii libcap-ng0:armhf 0.7.4-2 armhf An alternate POSIX capabilities library
ii libcap2:armhf 1:2.24-8 armhf POSIX 1003.1e capabilities (library)
ii libcap2-bin 1:2.24-8 armhf POSIX 1003.1e capabilities (utilities)
ii libcgi-fast-perl 1:2.04-1 all CGI subclass for work with FCGI
ii libcgi-pm-perl 4.09-1 all module for Common Gateway Interface applications
ii libclass-c3-perl 0.26-1 all pragma for using the C3 method resolution order
ii libclass-c3-xs-perl 0.13-2+b1 armhf Perl module to accelerate Class::C3
ii libcloog-isl4:armhf 0.18.2-1 armhf Chunky Loop Generator (runtime library)
ii libcomerr2:armhf 1.42.12-2 armhf common error description library
ii libcpan-meta-perl 2.142690-1 all Perl module to access CPAN distributions metadata
ii libcryptsetup4:armhf 2:1.6.6-5 armhf disk encryption support - shared library
ii libcurl3:armhf 7.38.0-4+deb8u5 armhf easy-to-use client-side URL transfer library (OpenSSL flavour)
ii libcurl3-gnutls:armhf 7.38.0-4+deb8u5 armhf easy-to-use client-side URL transfer library (GnuTLS flavour)
ii libcwidget3:armhf 0.5.17-2 armhf high-level terminal interface library for C++ (runtime files)
ii libdaemon0:armhf 0.14-6 armhf lightweight C library for daemons - runtime library
ii libdata-optlist-perl 0.109-1 all module to parse and validate simple name/value option pairs
ii libdata-section-perl 0.200006-1 all module to read chunks of data from a module's DATA section
ii libdb5.3:armhf 5.3.28-9 armhf Berkeley v5.3 Database Libraries [runtime]
ii libdbus-1-3:armhf 1.8.22-0+deb8u1 armhf simple interprocess messaging system (library)
ii libdebconfclient0:armhf 0.192 armhf Debian Configuration Management System (C-implementation library)
ii libdevmapper1.02.1:armhf 2:1.02.90-2.2+deb8u1 armhf Linux Kernel Device Mapper userspace library
ii libdns-export100 1:9.9.5.dfsg-9+deb8u10 armhf Exported DNS Shared Library
ii libdns100 1:9.9.5.dfsg-9+deb8u10 armhf DNS Shared Library used by BIND
ii libdpkg-perl 1.17.27 all Dpkg perl modules
ii libdrm2:armhf 2.4.71-1+rpi1 armhf Userspace interface to kernel DRM services -- runtime
ii libedit2:armhf 3.1-20140620-2 armhf BSD editline and history libraries
ii liberror-perl 0.17-1.1 all Perl module for error/exception handling in an OO-ish way
ii libestr0 0.1.9-1.1 armhf Helper functions for handling strings (lib)
ii libevent-2.0-5:armhf 2.0.21-stable-2+deb8u1 armhf Asynchronous event notification library
ii libexpat1:armhf 2.1.0-6+deb8u3 armhf XML parsing C library - runtime library
ii libfakeroot:armhf 1.20.2-1 armhf tool for simulating superuser privileges - shared libraries
ii libfam0 2.7.0-17.1 armhf Client library to control the FAM daemon
ii libfcgi-perl 0.77-1+deb8u1 armhf helper module for FastCGI
ii libffi6:armhf 3.1-2 armhf Foreign Function Interface library runtime
ii libfile-fcntllock-perl 0.22-1+b1 armhf Perl module for file locking with fcntl(2)
ii libfreetype6:armhf 2.6-2rpi1rpi1g armhf FreeType 2 font engine, shared library files
ii libfreetype6-dev 2.6-2rpi1rpi1g armhf FreeType 2 font engine, development files
ii libgcc-4.9-dev:armhf 4.9.2-10 armhf GCC support library (development files)
ii libgcc1:armhf 1:4.9.2-10 armhf GCC support library
ii libgcrypt20:armhf 1.6.3-2+deb8u2 armhf LGPL Crypto library - runtime library
ii libgdbm3:armhf 1.8.3-13.1 armhf GNU dbm database routines (runtime version)
ii libgeoip1:armhf 1.6.2-4 armhf non-DNS IP-to-country resolver library
ii libglib2.0-0:armhf 2.42.1-1 armhf GLib library of C routines
ii libglib2.0-data 2.42.1-1 all Common files for GLib library
ii libgmp10:armhf 2:6.0.0+dfsg-6+rpi1 armhf Multiprecision arithmetic library
ii libgnutls-deb0-28:armhf 3.3.8-6+deb8u4 armhf GNU TLS library - main runtime library
ii libgnutls-openssl27:armhf 3.3.8-6+deb8u4 armhf GNU TLS library - OpenSSL wrapper
ii libgomp1:armhf 4.9.2-10 armhf GCC OpenMP (GOMP) support library
ii libgpg-error0:armhf 1.17-3 armhf library for common error values and messages in GnuPG components
ii libgpm2:armhf 1.20.4-6.1 armhf General Purpose Mouse - shared library
ii libgssapi-krb5-2:armhf 1.12.1+dfsg-19+deb8u2 armhf MIT Kerberos runtime libraries - krb5 GSS-API Mechanism
ii libhogweed2:armhf 2.7.1-5+deb8u2 armhf low level cryptographic library (public-key cryptos)
ii libicu52:armhf 52.1-8+deb8u5 armhf International Components for Unicode
ii libident 0.22-3 armhf simple RFC1413 client library - runtime
ii libidn11:armhf 1.29-1+deb8u2 armhf GNU Libidn library, implementation of IETF IDN specifications
ii libirs-export91 1:9.9.5.dfsg-9+deb8u10 armhf Exported IRS Shared Library
ii libisc-export95 1:9.9.5.dfsg-9+deb8u10 armhf Exported ISC Shared Library
ii libisc95 1:9.9.5.dfsg-9+deb8u10 armhf ISC Shared Library used by BIND
ii libisccc90 1:9.9.5.dfsg-9+deb8u10 armhf Command Channel Library used by BIND
ii libisccfg-export90 1:9.9.5.dfsg-9+deb8u10 armhf Exported ISC CFG Shared Library
ii libisccfg90 1:9.9.5.dfsg-9+deb8u10 armhf Config File Handling Library used by BIND
ii libisl10:armhf 0.12.2-2 armhf manipulating sets and relations of integer points bounded by linear constrain
ii libiw30:armhf 30~pre9-8 armhf Wireless tools - library
ii libjim0.75:armhf 0.75-1 armhf small-footprint implementation of Tcl - shared library
ii libjpeg62-turbo:armhf 1:1.3.1-12 armhf libjpeg-turbo JPEG runtime library
ii libjson-c2:armhf 0.11-4 armhf JSON manipulation library - shared library
ii libk5crypto3:armhf 1.12.1+dfsg-19+deb8u2 armhf MIT Kerberos runtime libraries - Crypto Library
ii libkeyutils1:armhf 1.5.9-5 armhf Linux Key Management Utilities (library)
ii libklibc 2.0.4-2+rpi1 armhf minimal libc subset for use with initramfs
ii libkmod2:armhf 18-3 armhf libkmod shared library
ii libkrb5-3:armhf 1.12.1+dfsg-19+deb8u2 armhf MIT Kerberos runtime libraries
ii libkrb5support0:armhf 1.12.1+dfsg-19+deb8u2 armhf MIT Kerberos runtime libraries - Support library
ii libldap-2.4-2:armhf 2.4.40+dfsg-1+deb8u2 armhf OpenLDAP libraries
ii liblocale-gettext-perl 1.05-8+b1 armhf module using libc functions for internationalization in Perl
ii liblog-message-perl 0.8-1 all powerful and flexible message logging mechanism
ii liblog-message-simple-perl 0.10-2 all simplified interface to Log::Message
ii liblogging-stdlog0:armhf 1.0.4-1 armhf easy to use and lightweight logging library
ii liblognorm1:armhf 1.0.1-3 armhf Log normalizing library
ii libluajit-5.1-common 2.0.3+dfsg-3 all Just in time compiler for Lua - common files
ii liblwres90 1:9.9.5.dfsg-9+deb8u10 armhf Lightweight Resolver Library used by BIND
ii liblzma5:armhf 5.1.1alpha+20120614-2 armhf XZ-format compression library
ii libmagic1:armhf 1:5.22+15-2+deb8u3 armhf File type determination library using "magic" numbers
ii libmnl0:armhf 1.0.3-5 armhf minimalistic Netlink communication library
ii libmodule-build-perl 0.421000-2+deb8u1 all framework for building and installing Perl modules
ii libmodule-pluggable-perl 5.1-1 all module for giving modules the ability to have plugins
ii libmodule-signature-perl 0.73-1+deb8u2 all module to manipulate CPAN SIGNATURE files
ii libmount1:armhf 2.25.2-6 armhf device mounting library
ii libmpc3:armhf 1.0.2-1 armhf multiple precision complex floating-point library
ii libmpfr4:armhf 3.1.2-2 armhf multiple precision floating-point computation
ii libmro-compat-perl 0.12-1 all mro::* interface compatibility for Perls < 5.9.5
ii libncurses5:armhf 5.9+20140913-1 armhf shared libraries for terminal handling
ii libncursesw5:armhf 5.9+20140913-1 armhf shared libraries for terminal handling (wide character support)
ii libnetfilter-conntrack3:armhf 1.0.4-1 armhf Netfilter netlink-conntrack library
ii libnettle4:armhf 2.7.1-5+deb8u2 armhf low level cryptographic library (symmetric and one-way cryptos)
ii libnewt0.52:armhf 0.52.17-1 armhf Not Erik's Windowing Toolkit - text mode windowing with slang
ii libnfnetlink0:armhf 1.0.1-3 armhf Netfilter netlink library
ii libnfsidmap2:armhf 0.25-5 armhf NFS idmapping library
ii libnih-dbus1 1.0.3-4.3 armhf NIH D-Bus Bindings Library
ii libnih1 1.0.3-4.3 armhf NIH Utility Library
ii libnl-3-200:armhf 3.2.24-2 armhf library for dealing with netlink sockets
ii libnl-genl-3-200:armhf 3.2.24-2 armhf library for dealing with netlink sockets - generic netlink
ii libnss-mdns:armhf 0.10-6 armhf NSS module for Multicast DNS name resolution
ii libonig2:armhf 5.9.5-3.2 armhf Oniguruma regular expressions library
ii libopts25:armhf 1:5.18.4-3 armhf automated option processing library based on autogen
ii libp11-kit0:armhf 0.20.7-1 armhf Library for loading and coordinating access to PKCS#11 modules - runtime
ii libpackage-constants-perl 0.04-1 all List constants defined in a package
ii libpam-modules:armhf 1.1.8-3.1+deb8u2+rpi3 armhf Pluggable Authentication Modules for PAM
ii libpam-modules-bin 1.1.8-3.1+deb8u2+rpi3 armhf Pluggable Authentication Modules for PAM - helper binaries
ii libpam-runtime 1.1.8-3.1+deb8u2+rpi3 all Runtime support for the PAM library
ii libpam0g:armhf 1.1.8-3.1+deb8u2+rpi3 armhf Pluggable Authentication Modules library
ii libparams-util-perl 1.07-2+b1 armhf Perl extension for simple stand-alone param checking functions
ii libparted2:armhf 3.2-7 armhf disk partition manipulator - shared library
ii libpcre3:armhf 2:8.35-3.3+deb8u4 armhf Perl 5 Compatible Regular Expression Library - runtime files
ii libpcsclite1:armhf 1.8.13-1+deb8u1 armhf Middleware to access a smart card using PC/SC (library)
ii libperl4-corelibs-perl 0.003-1 all libraries historically supplied with Perl 4
ii libpipeline1:armhf 1.4.0-1 armhf pipeline manipulation library
ii libplymouth4:armhf 0.9.2-3+rpi1 armhf graphical boot animation and logger - shared libraries
ii libpng12-0:armhf 1.2.50-2+deb8u3 armhf PNG library - runtime
ii libpng12-dev:armhf 1.2.50-2+deb8u3 armhf PNG library - development
ii libpod-latex-perl 0.61-1 all module to convert Pod data to formatted LaTeX
ii libpod-readme-perl 0.11-1 all Perl module to convert POD to README file
ii libpopt0:armhf 1.16-10 armhf lib for parsing cmdline parameters
ii libprocps3:armhf 2:3.3.9-9 armhf library for accessing process information from /proc
ii libpsl0:armhf 0.5.1-1 armhf Library for Public Suffix List (shared libraries)
ii libpython-stdlib:armhf 2.7.9-1 armhf interactive high-level object-oriented language (default python version)
ii libpython2.7:armhf 2.7.9-2+deb8u1 armhf Shared Python runtime library (version 2.7)
ii libpython2.7-minimal:armhf 2.7.9-2+deb8u1 armhf Minimal subset of the Python language (version 2.7)
ii libpython2.7-stdlib:armhf 2.7.9-2+deb8u1 armhf Interactive high-level object-oriented language (standard library, version 2.
ii libqdbm14 1.8.78-5+b1 armhf QDBM Database Libraries without GDBM wrapper[runtime]
ii libraspberrypi-bin 1.20170427-1 armhf Miscellaneous Raspberry Pi utilities
ii libraspberrypi-dev 1.20170427-1 armhf EGL/GLES/OpenVG/etc. libraries for the Raspberry Pi's VideoCore IV (headers)
ii libraspberrypi-doc 1.20170427-1 armhf EGL/GLES/OpenVG/etc. libraries for the Raspberry Pi's VideoCore IV (headers)
ii libraspberrypi0 1.20170427-1 armhf EGL/GLES/OpenVG/etc. libraries for the Raspberry Pi's VideoCore IV
ii libreadline6:armhf 6.3-8 armhf GNU readline and history libraries, run-time libraries
ii libregexp-common-perl 2013031301-1 all module with common regular expressions
ii librtmp1:armhf 2.4+20150115.gita107cef armhf toolkit for RTMP streams (shared library)
ii libsamplerate0:armhf 0.1.8-8 armhf Audio sample rate conversion library
ii libsasl2-2:armhf 2.1.26.dfsg1-13+deb8u1 armhf Cyrus SASL - authentication abstraction library
ii libsasl2-modules:armhf 2.1.26.dfsg1-13+deb8u1 armhf Cyrus SASL - pluggable authentication modules
ii libsasl2-modules-db:armhf 2.1.26.dfsg1-13+deb8u1 armhf Cyrus SASL - pluggable authentication modules (DB)
ii libselinux1:armhf 2.3-2 armhf SELinux runtime shared libraries
ii libsemanage-common 2.3-1 all Common files for SELinux policy management libraries
ii libsemanage1:armhf 2.3-1 armhf SELinux policy management library
ii libsepol1:armhf 2.3-2 armhf SELinux library for manipulating binary security policies
ii libsigc++-1.2-5c2 1.2.7-2+b1 armhf type-safe Signal Framework for C++ - runtime
ii libsigc++-2.0-0c2a:armhf 2.4.0-1 armhf type-safe Signal Framework for C++ - runtime
ii libslang2:armhf 2.3.0-2 armhf S-Lang programming library - runtime version
ii libsmartcols1:armhf 2.25.2-6 armhf smart column output alignment library
ii libsoftware-license-perl 0.103010-3 all module providing templated software licenses
ii libsqlite3-0:armhf 3.8.7.1-1+deb8u2 armhf SQLite 3 shared library
ii libss2:armhf 1.42.12-2 armhf command-line interface parsing library
ii libssh2-1:armhf 1.4.3-4.1+deb8u1 armhf SSH2 client-side library
ii libssl1.0.0:armhf 1.0.1t-1+deb8u6 armhf Secure Sockets Layer toolkit - shared libraries
ii libstdc++-4.9-dev:armhf 4.9.2-10 armhf GNU Standard C++ Library v3 (development files)
ii libstdc++6:armhf 4.9.2-10 armhf GNU Standard C++ Library v3
ii libsub-exporter-perl 0.986-1 all sophisticated exporter for custom-built routines
ii libsub-install-perl 0.928-1 all module for installing subroutines into packages easily
ii libsysfs2:armhf 2.1.0+repack-4 armhf interface library to sysfs
ii libsystemd0:armhf 215-17+deb8u6 armhf systemd utility library
ii libtalloc2:armhf 2.1.2-0+deb8u1 armhf hierarchical pool based memory allocator
ii libtasn1-6:armhf 4.2-3+deb8u2 armhf Manage ASN.1 structures (runtime)
ii libterm-readkey-perl 2.32-1+b2 armhf perl module for simple terminal control
ii libterm-readline-perl-perl 1.0303-1 all Perl implementation of Readline libraries
ii libterm-ui-perl 0.42-1 all Term::ReadLine UI made easy
ii libtext-charwidth-perl 0.04-7+b4 armhf get display widths of characters on the terminal
ii libtext-iconv-perl 1.7-5+b5 armhf converts between character sets in Perl
ii libtext-soundex-perl 3.4-1+b2 armhf implementation of the soundex algorithm
ii libtext-template-perl 1.46-1 all perl module to process text templates
ii libtext-wrapi18n-perl 0.06-7 all internationalized substitute of Text::Wrap
ii libtimedate-perl 2.3000-2 all collection of modules to manipulate date/time information
ii libtinfo5:armhf 5.9+20140913-1 armhf shared low-level terminfo library for terminal handling
ii libtirpc1:armhf 0.2.5-1 armhf transport-independent RPC library
ii libubsan0:armhf 4.9.2-10 armhf UBSan -- undefined behaviour sanitizer (runtime)
ii libudev0:armhf 175-7.2 armhf libudev shared library
ii libudev1:armhf 215-17+deb8u6 armhf libudev shared library
ii libusb-0.1-4:armhf 2:0.1.12-25 armhf userspace USB programming library
ii libusb-1.0-0:armhf 2:1.0.19-1 armhf userspace USB programming library
ii libustr-1.0-1:armhf 1.0.4-3 armhf Micro string library: shared library
ii libuuid1:armhf 2.25.2-6 armhf Universally Unique ID library
ii libv4l-0:armhf 1.6.0-2 armhf Collection of video4linux support libraries
ii libv4l2rds0:armhf 1.6.0-2 armhf Video4Linux Radio Data System (RDS) decoding library
ii libv4lconvert0:armhf 1.6.0-2 armhf Video4linux frame format conversion library
ii libwbclient0:armhf 2:4.2.14+dfsg-0+deb8u5 armhf Samba winbind client library
ii libwrap0:armhf 7.6.q-25 armhf Wietse Venema's TCP wrappers library
ii libx11-6:armhf 2:1.6.2-3 armhf X11 client-side library
ii libx11-data 2:1.6.2-3 all X11 client-side library
ii libxapian22 1.2.19-1+deb8u1 armhf Search engine library
ii libxau6:armhf 1:1.0.8-1 armhf X11 authorisation library
ii libxcb1:armhf 1.10-3 armhf X C Binding
ii libxdmcp6:armhf 1:1.1.1-1 armhf X11 Display Manager Control Protocol library
ii libxext6:armhf 2:1.3.3-1 armhf X11 miscellaneous extension library
ii libxml2:armhf 2.9.1+dfsg1-5+deb8u4 armhf GNOME XML library
ii libxmuu1:armhf 2:1.1.2-1 armhf X11 miscellaneous micro-utility library
ii libxtables10 1.4.21-2 armhf netfilter xtables library
ii lighttpd 1.4.35-4+deb8u1 armhf fast webserver with minimal memory footprint
ii linux-libc-dev:armhf 3.16.7-ckt11-1+deb8u4+r armhf Linux support headers for userspace development
ii locales 2.19-18+deb8u7 all GNU C Library: National Language (locale) data [support]
ii login 1:4.2-3+deb8u3 armhf system login tools
ii logrotate 3.8.7-1 armhf Log rotation utility
ii lsb-base 4.1+Debian13+rpi1+nmu1 all Linux Standard Base 4.1 init script functionality
ii lsb-release 4.1+Debian13+rpi1+nmu1 all Linux Standard Base version reporting utility
ii lsof 4.86+dfsg-1 armhf Utility to list open files
ii lua5.1 5.1.5-7.1 armhf Simple, extensible, embeddable programming language
ii luajit 2.0.3+dfsg-3 armhf Just in time compiler for Lua programming language version 5.1
ii make 4.0-8.1 armhf utility for directing compilation
ii makedev 2.3.1-93 all creates device files in /dev
ii man-db 2.7.0.2-5 armhf on-line manual pager
ii manpages 3.74-1 all Manual pages about using a GNU/Linux system
ii manpages-dev 3.74-1 all Manual pages about using GNU/Linux for development
ii mawk 1.3.3-17 armhf a pattern scanning and text processing language
ii mc 3:4.8.13-3 armhf Midnight Commander - a powerful file manager
ii mc-data 3:4.8.13-3 all Midnight Commander - a powerful file manager -- data files
ii mime-support 3.58 all MIME files 'mime.types' & 'mailcap', and support programs
ii module-init-tools 18-3 all transitional dummy package (module-init-tools to kmod)
ii mount 2.25.2-6 armhf Tools for mounting and manipulating filesystems
ii mountall 2.54 armhf filesystem mounting tool
ii multiarch-support 2.19-18+deb8u7 armhf Transitional package to ensure multiarch compatibility
ii nano 2.2.6-3 armhf small, friendly text editor inspired by Pico
ii ncdu 1.10-1 armhf ncurses disk usage viewer
ii ncurses-base 5.9+20140913-1 all basic terminal type definitions
ii ncurses-bin 5.9+20140913-1 armhf terminal-related programs and man pages
ii ncurses-term 5.9+20140913-1 all additional terminal type definitions
ii net-tools 1.60-26 armhf NET-3 networking toolkit
ii netbase 5.3 all Basic TCP/IP networking system
ii netcat 1.10-41 all TCP/IP swiss army knife -- transitional package
ii netcat-openbsd 1.105-7 armhf TCP/IP swiss army knife
ii netcat-traditional 1.10-41 armhf TCP/IP swiss army knife
ii nfs-common 1:1.2.8-9 armhf NFS support files common to client and server
ii ntp 1:4.2.6.p5+dfsg-7+deb8u armhf Network Time Protocol daemon and utility programs
ii openresolv 3.5.2-1 all management framework for resolv.conf
ii openssh-client 1:6.7p1-5+deb8u3 armhf secure shell (SSH) client, for secure access to remote machines
ii openssh-server 1:6.7p1-5+deb8u3 armhf secure shell (SSH) server, for secure access from remote machines
ii openssh-sftp-server 1:6.7p1-5+deb8u3 armhf secure shell (SSH) sftp server module, for SFTP access from remote machines
ii openssl 1.0.1t-1+deb8u6 armhf Secure Sockets Layer toolkit - cryptographic utility
ii parted 3.2-7 armhf disk partition manipulator
ii passwd 1:4.2-3+deb8u3 armhf change and administer password and group data
ii patch 2.7.5-1 armhf Apply a diff file to an original
ii perl 5.20.2-3+deb8u6 armhf Larry Wall's Practical Extraction and Report Language
ii perl-base 5.20.2-3+deb8u6 armhf minimal Perl system
ii perl-modules 5.20.2-3+deb8u6 all Core Perl modules
ii php5-cgi 5.6.30+dfsg-0+deb8u1 armhf server-side, HTML-embedded scripting language (CGI binary)
ii php5-cli 5.6.30+dfsg-0+deb8u1 armhf command-line interpreter for the php5 scripting language
ii php5-common 5.6.30+dfsg-0+deb8u1 armhf Common files for packages built from the php5 source
ii php5-json 1.3.6-1 armhf JSON module for php5
ii pi-bluetooth 0.1.3 armhf Raspberry Pi 3 bluetooth
ii pkg-config 0.28-1 armhf manage compile and link flags for libraries
ii plymouth 0.9.2-3+rpi1 armhf boot animation, logger and I/O multiplexer
ii procps 2:3.3.9-9 armhf /proc file system utilities
ii psmisc 22.21-2 armhf utilities that use the proc file system
ii python 2.7.9-1 armhf interactive high-level object-oriented language (default version)
ii python-apt 0.9.3.12 armhf Python interface to libapt-pkg
ii python-apt-common 0.9.3.12 all Python interface to libapt-pkg (locales)
ii python-minimal 2.7.9-1 armhf minimal subset of the Python language (default version)
ii python-rpi.gpio 0.6.3~jessie-1 armhf Python GPIO module for Raspberry Pi
ii python-support 1.0.15 all automated rebuilding support for Python modules
ii python2.7 2.7.9-2+deb8u1 armhf Interactive high-level object-oriented language (version 2.7)
ii python2.7-minimal 2.7.9-2+deb8u1 armhf Minimal subset of the Python language (version 2.7)
ii raspberrypi-bootloader 1.20170427-1 armhf Raspberry Pi bootloader
ii raspberrypi-kernel 1.20170427-1 armhf Raspberry Pi bootloader
ii raspberrypi-net-mods 1.2.5 all Network configuration for the Raspberry Pi UI
ii raspberrypi-sys-mods 20170313 all System tweaks for the Raspberry Pi
ii raspbian-archive-keyring 20120528.2 all GnuPG archive keys of the raspbian archive
ii raspi-config 20170503 all Raspberry Pi configuration tool
ii raspi-copies-and-fills 0.5-1 armhf ARM-accelerated versions of selected functions from string.h
ii readline-common 6.3-8 all GNU readline and history libraries, common files
ii rename 0.20-3 all Perl extension for renaming multiple files
ii rpcbind 0.2.1-6+deb8u1 armhf converts RPC program numbers into universal addresses
ii rsyslog 8.4.2-1+deb8u2 armhf reliable system and kernel logging daemon
ii samba-common 2:4.2.14+dfsg-0+deb8u5 all common files used by both the Samba server and client
ii sed 4.2.2-4+deb8u1 armhf The GNU sed stream editor
ii sensible-utils 0.0.9 all Utilities for sensible alternative selection
ii sgml-base 1.26+nmu4 all SGML infrastructure and SGML catalog file support
ii shared-mime-info 1.3-1 armhf FreeDesktop.org shared MIME database and spec
ii ssh 1:6.7p1-5+deb8u3 all secure shell client and server (metapackage)
ii startpar 0.59-3 armhf run processes in parallel and multiplex their output
ii strace 4.9-2 armhf System call tracer
ii sudo 1.8.10p3-1+deb8u3 armhf Provide limited super user privileges to specific users
ii systemd 215-17+deb8u6 armhf system and service manager
ii systemd-sysv 215-17+deb8u6 armhf system and service manager - SysV links
ii sysv-rc 2.88dsf-59 all System-V-like runlevel change mechanism
ii sysvinit-utils 2.88dsf-59 armhf System-V-like utilities
ii tar 1.27.1-2 armhf GNU version of the tar archiving utility
ii tasksel 3.31+deb8u1 all tool for selecting tasks for installation on Debian systems
ii tasksel-data 3.31+deb8u1 all official tasks used for installation of Debian systems
ii tcpd 7.6.q-25 armhf Wietse Venema's TCP wrapper utilities
ii traceroute 1:2.0.20-2 armhf Traces the route taken by packets over an IPv4/IPv6 network
ii tree 1.7.0-3 armhf displays an indented directory tree, in color
ii triggerhappy 0.3.4-2 armhf global hotkey daemon for Linux
ii tzdata 2016j-0+deb8u1 all time zone and daylight-saving time data
ii ucf 3.0030 all Update Configuration File(s): preserve user changes to config files
ii udev 215-17+deb8u6 armhf /dev/ and hotplug management daemon
ii unzip 6.0-16+deb8u2 armhf De-archiver for .zip files
ii usb-modeswitch 2.2.0+repack0-2 armhf mode switching tool for controlling "flip flop" USB devices
ii usb-modeswitch-data 20150115-1 all mode switching data for usb-modeswitch
ii usbutils 1:007-2 armhf Linux USB utilities
ii util-linux 2.25.2-6 armhf Miscellaneous system utilities
ii v4l-utils 1.6.0-2 armhf Collection of command line video4linux utilities
ii vim-common 2:7.4.488-7+deb8u2 armhf Vi IMproved - Common files
ii vim-tiny 2:7.4.488-7+deb8u2 armhf Vi IMproved - enhanced vi editor - compact version
ii wget 1.16-1+deb8u1 armhf retrieves files from the web
ii whiptail 0.52.17-1 armhf Displays user-friendly dialog boxes from shell scripts
ii whois 5.2.7 armhf intelligent WHOIS client
ii wireless-regdb 2016.06.10-1~deb8u1 all wireless regulatory database
ii wireless-tools 30~pre9-8 armhf Tools for manipulating Linux Wireless Extensions
ii wpasupplicant 2.3-1+deb8u4 armhf client support for WPA and WPA2 (IEEE 802.11i)
ii xauth 1:1.0.9-1 armhf X authentication utility
ii xdg-user-dirs 0.15-2 armhf tool to manage well known user directories
ii xkb-data 2.12-1 all X Keyboard Extension (XKB) configuration data
ii xml-core 0.13+nmu2 all XML infrastructure and XML catalog file support
ii xz-utils 5.1.1alpha+20120614-2 armhf XZ-format compression utilities
ii zlib1g:armhf 1:1.2.8.dfsg-2 armhf compression library - runtime
ii zlib1g-dev:armhf 1:1.2.8.dfsg-2 armhf compression library - development
