Dnsmasq "localise-queries" checkbox in DNS settings
Since v6 it is no longer possible to disable the dnsmasq option "localise-queries". It is enabled by default and cannot be changed through the provided custom dnsmasq settings or by editing /etc/pihole/dnsmasq.conf.
Since I personally would like to disable this option I would like to suggest to create a checkbox for this, just like others, in the advanced section of the DNS config, with it being enabled by default.
Implementation ongoing:
Implemented in #2524
