can anyone help me, so it doesn't SERVFAIL
Thanks,
We will need some more details.
Has unbound worked in the past, but now no longer works?
Is the time on the Pi correct for your location?
Have you made any system changes since original install - upgrade of your OS, etc.?
I'm using armbian jammy, I see the time the location of the os is different from my location.
I've changed to my current location.
if there is still a problem I will tell him here.
Thanks.
oh, it turned out to be the same, even though my os only installed pihole and doh cloudflare. I haven't made any changes in my os.
