This looks like a common problem and I'm not sure if there's already a solution to it. This is how I have the docker container configured, very simple:
pihole:
image: pihole/pihole:v5.2.1
container_name: pihole
hostname: pihole.condo.arpa
volumes:
- /home/kevin/appdata/pihole/etc-pihole:/etc/pihole
- /home/kevin/appdata/pihole/etc-dnsmasq.d:/etc/dnsmasq.d
- /home/kevin/appdata/proxy/wpad.dat:/var/www/html/wpad.da
- /home/kevin/appdata/proxy/wpad.dat:/var/www/html/wpad.dat
- /home/kevin/appdata/proxy/wpad.dat:/var/www/html/proxy.pac
mac_address: fa:af:f7:2e:f5:97
networks:
physical_macvlan_network:
ipv4_address: 192.168.20.100
dns:
- 127.0.0.1
- 8.8.4.4
restart: unless-stopped
environment:
- PUID=${PUID}
- PGID=${PGID}
- TZ=Asia/Manila
Everytime I enable DNSSEC and configure conditional forwarding, they get reset every after container restart. This seems to be a very common issue and I'm surprised it's not fixed until now. Do I have to "force" the values of these DNS settings by using all the environment variables for them? Clearly, these variables are marked as "optional" so why do I need to be using them to be able to set my DNS settings? It's kinda counterproductive, no?
Also, I know that to be able to use multiple conditional forwarders, I need to manually edit dnsmasq.d. But how will even achieve that if everything after restart that config file is written with a fresh copy?
