DNS Service not running
Running Pi-Hole on Hyper-V VM image of centos. It was working fine on a different computer but I had to reinstall it and then import the VM back again. I updated the server using "pihole -up", at the end it said DNS service is not running and.
I restarted the server a few times and the services also.
The admin panel says "DNS service not running" and instead of numbers in the colored cards I see "Lost connection to API".
Running pihole-FTL I get an error:
pihole-FTL: /lib64/libc.so.6: version 'GLIBC_2.28' not found (required by pihole-FTL)
https://tricorder.pi-hole.net/k08bs1jmi9
We just fixed this (we accidentially dropped support for older distributions), please update again.
Works, thank you!
In my case it is not working anymore. I have even installed from beginning trough WSL1, DNS is not running, but querry log seems to be filled with requests.
