DNS service running
DNS Service not running. I using wsl ubuntu on windows 10
x29z6i71sm
Looking at your debug log, it seems you don't have a correctly configured gateway.
See
i using command ip -4 route | grep default it return:
You ran the ip -4 command on a machine called DESKTOP-N7AQISB. Is this the machine Pi-hole is installed on? If not, please run the command on the Pi-hole. If yes, please generate and upload another debug log.
@DanSchaper @PromoFaux I'm completely unfamiliar with Windows. Is this even supported? Do you know of any installation under these circumstances that work?
It's not possible for Pi-hole to be installed in WSL. I had some success with WSL2 when I tried the preview, but that is not available generally yet.
Best bet for Windows would be to use the docker container.
