DNS Service starting
DNS Service not running
xz26y0lwz2
Dear team,
my pihole-installation was running perfectly fine until I updated stubby this morning and changed the listen address to 127.0.0.2#53 (as 5353, which is used before is used by the avahi-daemon.
However, changing that back didn't help.
I'm a little confused that the debug output tells me that 127.0.0.2:53 is used by pihole-FTL as it's used by stubby (which is working fine btw with dig @127.0.0.2 pi-hole.net)
If been searching the forum for hours now and checked all the possible answers for my issue but unfortunately nothing helps.
As dnsmasq is used within pihole now, I disabled the service so that shouldn't conflict. However, here's the output of journalctl -xe if that helps:
Feb 16 12:19:41 RasPi dnsmasq[16422]: dnsmasq: bad option at line 44 of /etc/dnsmasq.d/01-pihole.conf
Feb 16 12:19:41 RasPi dnsmasq[16422]: bad option at line 44 of /etc/dnsmasq.d/01-pihole.conf
Feb 16 12:19:41 RasPi dnsmasq[16422]: FAILED to start up
Feb 16 12:19:41 RasPi systemd[1]: dnsmasq.service: Control process exited, code=exited status=1
Feb 16 12:19:41 RasPi systemd[1]: Failed to start dnsmasq - A lightweight DHCP and caching DNS server.
-- Subject: Unit dnsmasq.service has failed
I would be very grateful (and maybe others which find this thread) if I could assistance with troubleshooting.
You may have a two part problem here. Something is keeping pihole-FTL from running, and there have been separate reports of problems running Pi-Hole alongside Stubby.
What is the output of this command which will show processes running on ports used by Pi-Hole:
While checking the forum I just noticed that somebody else has a similar problem which also occurs with stubby.
Following that thread I delayed the stubby startup by 30 seconds so it starts after pihole-FTL now.
However, that's only a workaround, as it doesn't solve the problem.
If everything is running (pihole-FTL first, stubby afterwards) this is the result of the command:
