DNS Service not running
name resolution
not finding any dns names
9nfk9or5u5
I am running on a debain stretch and have been for months. Last night it stopped working. I shutdown that instance and brought up a second. I did all updates to OS and PIHOLE. only status I can find is DNS service is not running. Any help would be great.
Your debug log shows that piHole-FTL is not running:
*:80 lighttpd (IPv4)
*:80 lighttpd (IPv6)
[✗] Failed to resolve fili.tv via localhost (127.0.0.1)
[✗] Failed to resolve fili.tv via Pi-hole (10.0.69.22)
[✓] doubleclick.com is 108.177.112.113 via a remote, public DNS server (8.8.8.8)
Try running this command to restart FTL.
sudo service pihole-FTL restart
If that does not resolve it, reset your namserver to a public DNS and then repair
sudo nano /etc/resolv.conf
Change 127.0.0.1 to 1.1.1.1, save and exit
pihole -r and select "repair"
The FTL restart did not work.
Repair did not work.
[✓] Enabling pihole-FTL service to start on reboot
[✓] Deleting existing list cache
[✗] DNS service is not running
[✓] Starting DNS service
[✗] DNS resolution is not available
So I did a reboot and did not work either. I had already done the repair several times.
Please upload another debug log and post the token.
jwt5p7l8jb
I have not seen a reply to the last diagnostics. Let me know if I need to provide another.
Run this command and post the output:
pihole checkout master
That seemed to have resolved the issue.
do you still want the output?
pi@raspberry:/var/log $ pihole checkout master
  Please note that changing branches severely alters your Pi-hole subsystems
  Features that work on the master branch, may not on a development branch
  This feature is NOT supported unless a Pi-hole developer explicitly asks!
  Have you read and understood this? [y/N] y
  [i] Shortcut "master" detected - checking out master branches...
  [i] Pi-hole core
fatal: ref HEAD is not a symbolic ref
  [✓] Switching to branch: 'master' from ''
Updating 1e87850..ddbdb51
Fast-forward
 .editorconfig                                |    2 +-
 .github/dco.yml                              |    2 +
 .gitignore                                   |    5 +
 .idea/codeStyles/Project.xml                 |    6 -
 .pullapprove.yml                             |   38 -
 .stickler.yml                                |    3 +
 .travis.yml                                  |    4 +-
 CONTRIBUTING.md                              |    2 -
 README.md                                    |   71 +-
 adlists.default                              |   23 -
 advanced/Scripts/chronometer.sh              |  950 ++++---
 advanced/Scripts/list.sh                     |  365 +--
 advanced/Scripts/piholeCheckout.sh           |  470 +---
 advanced/Scripts/piholeDebug.sh              | 1821 ++++++------
 advanced/Scripts/piholeLogFlush.sh           |   70 +-
 advanced/Scripts/query.sh                    |  239 ++
 advanced/Scripts/setupLCD.sh                 |   34 +-
 advanced/Scripts/update.sh                   |  303 +-
 advanced/Scripts/updatecheck.sh              |   64 +-
 advanced/Scripts/version.sh                  |  224 +-
 advanced/Scripts/webpage.sh                  |  662 ++---
 advanced/Scripts/wildcard_regex_converter.sh |   28 +
 advanced/{ => Templates}/logrotate           |    0
 advanced/Templates/pihole-FTL.conf           |   84 +
 advanced/{ => Templates}/pihole-FTL.service  |   23 +-
 advanced/{ => Templates}/pihole.cron         |    0
 advanced/{ => Templates}/pihole.sudo         |    0
 advanced/bash-completion/pihole              |   74 +-
 advanced/index.php                           |   31 +-
 automated install/basic-install.sh           | 3833 ++++++++++++++------------
 automated install/uninstall.sh               |  328 ++-
 gravity.sh                                   |  159 +-
 manpages/pihole-FTL.8                        |  112 +
 manpages/pihole-FTL.conf.5                   |  102 +
 manpages/pihole.8                            |  361 +++
 pihole                                       |  286 +-
 requirements.txt                             |    1 +
 setup.py                                     |    6 +
 test/README.md                               |   25 +
 test/conftest.py                             |  113 +-
 test/fedora.Dockerfile                       |   16 +
 test/test_000_build_containers.py            |    9 +-
 test/test_automated_install.py               |  497 +++-
 test/test_centos_fedora_support.py           |  209 ++
 test/test_shellcheck.py                      |   11 +-
 tox.ini                                      |   10 +
 46 files changed, 6641 insertions(+), 5035 deletions(-)
 create mode 100644 .github/dco.yml
 delete mode 100644 .pullapprove.yml
 delete mode 100644 adlists.default
 create mode 100644 advanced/Scripts/query.sh
 create mode 100644 advanced/Scripts/wildcard_regex_converter.sh
 rename advanced/{ => Templates}/logrotate (100%)
 create mode 100644 advanced/Templates/pihole-FTL.conf
 rename advanced/{ => Templates}/pihole-FTL.service (75%)
 rename advanced/{ => Templates}/pihole.cron (100%)
 rename advanced/{ => Templates}/pihole.sudo (100%)
 create mode 100644 manpages/pihole-FTL.8
 create mode 100644 manpages/pihole-FTL.conf.5
 create mode 100644 manpages/pihole.8
 create mode 100644 setup.py
 create mode 100644 test/README.md
 create mode 100644 test/fedora.Dockerfile
 create mode 100644 test/test_centos_fedora_support.py
 create mode 100644 tox.ini
  [i] Web interface
Updating e48aa295..af8c926c
Fast-forward
 README.md                            | 194 ++++++++-
 api.php                              |  40 +-
 api_FTL.php                          | 528 +++++++++++-----------
 api_PHP.php                          |  93 ----
 api_db.php                           |  95 +++-
 gravity.php                          |   4 +-
 help.php                             |  42 +-
 index.php                            |  80 ++--
 list.php                             |  12 +-
 queries.php                          |  30 +-
 queryads.php                         |   2 +-
 scripts/pi-hole/js/db_queries.js     |   8 +-
 scripts/pi-hole/js/index.js          | 219 +++++++++-
 scripts/pi-hole/js/list.js           |  77 ++--
 scripts/pi-hole/js/queries.js        | 128 ++++--
 scripts/pi-hole/js/settings.js       |  13 +-
 scripts/pi-hole/js/taillog-FTL.js    |  11 +-
 scripts/pi-hole/js/taillog.js        |  11 +-
 scripts/pi-hole/php/FTL.php          | 104 +----
 scripts/pi-hole/php/add.php          |  15 +-
 scripts/pi-hole/php/api_token.php    |   3 +
 scripts/pi-hole/php/auth.php         |  11 +-
 scripts/pi-hole/php/data.php         | 822 -----------------------------------
 scripts/pi-hole/php/func.php         |  17 +
 scripts/pi-hole/php/get.php          |  55 +--
 scripts/pi-hole/php/gravity.php      |  51 +++
 scripts/pi-hole/php/header.php       |  17 +-
 scripts/pi-hole/php/loginpage.php    |   3 +
 scripts/pi-hole/php/password.php     |  27 +-
 scripts/pi-hole/php/queryads.php     |   2 +-
 scripts/pi-hole/php/savesettings.php |  76 +++-
 scripts/pi-hole/php/sub.php          |  26 +-
 scripts/pi-hole/php/teleporter.php   |  68 ++-
 settings.php                         | 217 ++++++---
 style/pi-hole.css                    |  62 ++-
 taillog-FTL.php                      |   2 +-
 taillog.php                          |   2 +-
 37 files changed, 1492 insertions(+), 1675 deletions(-)
 delete mode 100644 api_PHP.php
 delete mode 100644 scripts/pi-hole/php/data.php
 create mode 100644 scripts/pi-hole/php/gravity.php
  [✓] Detected 32bit (i686) architecture
  [i] Running installer to upgrade your installation
  [✓] Root user check
        .ccccc:,.
         :cccclll:.      ..,,
          :ccccclll.   ;ooodc
           'ccll:;ll .oooodc
             .;cll.;;looo:.
  [i] Existing PHP installation detected : PHP version 7.0.30-0+deb9u1
  [i] Performing unattended setup, no whiptail dialogs will be displayed
  [✓] Disk space check
  [✓] Checking apt-get for upgraded packages... 40 updates available
  [i] It is recommended to update your OS after installing the Pi-hole!
  [✓] Checking for apt-utils
  [✓] Checking for dialog
  [✓] Checking for debconf
  [✓] Checking for dhcpcd5
  [✓] Checking for git
  [✓] Checking for iproute2
  [✓] Checking for whiptail
  [✓] Check for existing repository in /etc/.pihole
  [✓] Update repo in /etc/.pihole
  [✓] Check for existing repository in /var/www/html/admin
  [✓] Update repo in /var/www/html/admin
  [i] Main Dependency checks...
  [✓] Checking for bc
  [✓] Checking for cron
  [✓] Checking for curl
  [✓] Checking for dnsutils
  [✓] Checking for iputils-ping
  [✓] Checking for lsof
  [✓] Checking for netcat
  [✓] Checking for psmisc
  [✓] Checking for sudo
  [✓] Checking for unzip
  [✓] Checking for wget
  [✓] Checking for idn2
  [✓] Checking for sqlite3
  [✓] Checking for libcap2-bin
  [✓] Checking for resolvconf
  [✓] Checking for lighttpd
  [✓] Checking for php7.0-common
  [✓] Checking for php7.0-cgi
  [✓] Checking for php7.0-sqlite3
  [✓] Enabling lighttpd service to start on reboot
  [✓] Installing scripts from /etc/.pihole
  [✓] Copying 01-pihole.conf to /etc/dnsmasq.d/01-pihole.conf
  [i] Installing blocking page...
  [✓] Creating directory for blocking page, and copying files
  [✗] Backing up index.lighttpd.html
  [✓] Installing sudoer file
  [✓] Installing latest Cron script
  [✓] Installing latest logrotate script
  [i] FTL Checks...
  [i] Latest FTL Binary already installed (v4.0). Confirming Checksum...
  [i] Checksum correct. No need to download!
  [✓] man pages installed and database updated
  [i] Systemd-resolved is not enabled
  [✓] Starting lighttpd service
  [i] Restarting services...
  [✓] Starting pihole-FTL service
  [i] Target: raw.githubusercontent.com (hosts)
  [i] Target: mirror1.malwaredomains.com (justdomains)
  [i] Target: sysctl.org (hosts)
  [i] Target: zeustracker.abuse.ch (blocklist.php?download=domainblocklist)
  [i] Target: s3.amazonaws.com (simple_tracking.txt)
  [i] Target: s3.amazonaws.com (simple_ad.txt)
  [✓] Consolidating blocklists
  [✓] Extracting domains from blocklists
  [i] Number of domains being pulled in by gravity: 161888
  [✓] Removing duplicate domains
  [i] Number of unique domains trapped in the Event Horizon: 138706
  [i] Number of whitelisted domains: 6
  [i] Number of regex filters: 0
  [✓] Parsing domains into hosts format
  [✓] Cleaning up stray matter
  [✓] Force-reloading DNS service
  [✓] DNS service is running
  [i] The install log is located at: /etc/pihole/install.log
    Update Complete!
  Current Pi-hole version is v4.0
  Current AdminLTE version is v4.0
  Current FTL version is v4.0
Glad that you got it updated. Looks like you're up and running again.
Thanks for all the help.
