instead of lighttpd
Running Pi-Hole on DigitalOcean of CentOS 8.2, it works great before I update the Pi-hole version.
I updated the server using "pihole -up" today, at the end it said DNS service is not running.
Either update Pi-hole or fresh install it will got the same problem.
If I run "pihole updateGravity", I got the message as below:
/usr/local/bin/pihole: line 284: lsof: command not found
[✗] DNS service is NOT listening
