pi@raspberry:~ $ pihole -r
[✓] Root user check
.ccccc:,.
:cccclll:. ..,,
:ccccclll. ;ooodc
'ccll:;ll .oooodc
.;cll.;;looo:.
[i] Existing PHP installation detected : PHP version 7.3.19-1~deb10u1
[i] Repair option selected
[✓] Checking for dhcpcd5
[✓] Checking for git
[✓] Checking for iproute2
[✓] Checking for whiptail
[✓] Checking for dnsutils
[✓] Supported OS detected
[i] SELinux not detected
[i] Performing reconfiguration, skipping download of local repos
[✓] Resetting repository within /etc/.pihole...
[✓] Resetting repository within /var/www/html/admin...
[i] Main Dependency checks...
[✓] Checking for cron
[✓] Checking for curl
[✓] Checking for iputils-ping
[✓] Checking for lsof
[✓] Checking for netcat
[✓] Checking for psmisc
[✓] Checking for sudo
[✓] Checking for unzip
[✓] Checking for wget
[✓] Checking for idn2
[✓] Checking for sqlite3
[✓] Checking for libcap2-bin
[✓] Checking for lighttpd
[✓] Checking for php7.3-common
[✓] Checking for php7.3-cgi
[✓] Checking for php7.3-sqlite3
[✓] Checking for php7.3-xml
[✓] Checking for php7.3-json
[✓] Checking for php7.3-intl
[✓] Enabling lighttpd service to start on reboot...
[i] FTL Checks...
[✓] Detected x86_64 processor
/etc/.pihole/automated install/basic-install.sh: line 2543: /usr/bin/pihole-FTL: No such file or directory
[✓] Downloading and Installing FTL
[✓] Installing scripts from /etc/.pihole
[✓] Copying 01-pihole.conf to /etc/dnsmasq.d/01-pihole.conf
[i] Installing blocking page...
[✓] Creating directory for blocking page, and copying files
[i] Backing up index.lighttpd.html
[✓] Installing sudoer file
[✓] Installing latest Cron script
[✓] Installing latest logrotate script
[i] Backing up /etc/dnsmasq.conf to /etc/dnsmasq.conf.old
[✓] man pages installed and database updated
[i] Testing if systemd-resolved is enabled
[i] Systemd-resolved is not enabled
[✓] Restarting lighttpd service...
[i] Restarting services...
[✓] Enabling pihole-FTL service to start on reboot...
[✓] Restarting pihole-FTL service...
[✓] Deleting existing list cache
[i] Using libz compression
[i] Received 58787 domains
[i] Target: https://mirror1.malwaredomains.com/files/justdomains
[✗] Status: Not found
[✗] List download failed: no cached list available
[✓] Storing downloaded domains in new gravity database
[✓] Building tree
[✓] Swapping databases
[i] Number of gravity domains: 58787 (58787 unique domains)
[i] Number of exact blacklisted domains: 0
[i] Number of regex blacklist filters: 0
[i] Number of exact whitelisted domains: 0
[i] Number of regex whitelist filters: 0
[✓] Cleaning up stray matter
[✓] Restarting DNS server
[✗] DNS service is NOT listening
/opt/pihole/updatecheck.sh: line 77: /usr/bin/pihole-FTL: No such file or directory
/opt/pihole/updatecheck.sh: line 91: /usr/bin/pihole-FTL: No such file or directory
[i] The install log is located at: /etc/pihole/install.log
Update Complete!
Current Pi-hole version is v5.2.1.
Current AdminLTE version is v5.2.1.
/opt/pihole/version.sh: line 19: /usr/bin/pihole-FTL: No such file or directory
/opt/pihole/version.sh: line 122: /usr/bin/pihole-FTL: No such file or directory
Invalid Option! Try 'pihole -v --help' for more information.
Token //tricorder.pi-hole.net/3ryc6so733
