after updating my pihole running on my Raspberry pi 3b it stops running
dns start
red dot on dashboard
dns start
Your debug log shows a rather old pihole-FTL:
[✓] FTL: v4.3.1 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
What Pi-hole version did you update from?
[i] Core: v5.17.1 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Web: v5.20.1 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
Your FTL was not updated.
Now you have the latest Pi-hole core, but a very old v4 FTL.
Try to update again.
thanks for reply, if i try to update it by "sudo pihole -up" it says that "it's impossible to find php7-3intl
not sure about version, but very old (2 or 3 years old)
You're running an rather old OS that has reached EOL. Consider installing a more recent one
[✓] Raspbian GNU/Linux 10 (buster)
Thanks folks, you were right!
After uograding to pi os and reinstall piHole everything works fine!
Thanks!
