DNS service is NOT running
Hi, everyone! Seems I got a problem. And I need help.
Pi-hole resolve domains and block ads properly.
[pi@RasPi-KB ~]$ pihole status
  [✗] DNS service is NOT running
Can't be solved by pihole restartdns or pihole -r.
[✗]  There was an error uploading your debug log.
Get the output from sudo systemctl status --full --no-pager pihole-FTL.service please.
Thanks for your reply.
   Active: active (exited) since Thu 2020-06-18 00:37:15 CST; 6
h ago
  Process: 10779 ExecStart=/etc/init.d/pihole-FTL start (code=e
xited, status=0/SUCCESS)
Jun 18 00:37:15 RasPi-KB systemd[1]: Starting LSB: pihole-FTL d
aemon...
Jun 18 00:37:15 RasPi-KB pihole-FTL[10779]: Not running
Jun 18 00:37:15 RasPi-KB su[10803]: (to pihole) root on none
Jun 18 00:37:15 RasPi-KB su[10803]: pam_unix(su:session): sessi
on opened for user pihole by (uid=0)
Jun 18 00:37:15 RasPi-KB pihole-FTL[10779]: dnsmasq: bad addres
s at line 15 of /mnt/ks/.confs/dnsmasq/github.conf
on closed for user pihole
Jun 18 00:37:15 RasPi-KB systemd[1]: Started LSB: pihole-FTL da
emon.
Fix that and it should work.
Worked for me.
Thank you very much!
