Ive been running PiHole in my docker stack without any issue. Restarted the whole stack after changing other containers and now PiHole will not finish starting up. Any suggestions are appreciated.
Try destroying the whole container and stand up a fresh one.
Ive squashed and rebuild the container a few times with no luck. Looks like it had something to do with either the dnsmasq.d directory or Pihole directory data. Going to try and and narrow it down to a single file.
Welp. Ive got no explanation. Squashed both directories and it worked without any of my settings or data. Put my data back completely unmodified and suddenly its working. The only thing different is that in this particular instance Im sitting in front of the computer instead of issuing commands via SSH.
Either way its working now. Thanks!
