DNS service is not Running and does not start
Pi-Hole should just start
It says that the dns service was restarted, but if I check it afterwards with pihole status it says
pzirt9s19i!
Summary
I know there have been a lot of topics with a similar problem, but none of them helped me fixing mine. I made a fresh install of Pi-Hole on a Debian 8 machine. I tried reinstalling multiple times. I tried repair too.
The output of
sudo systemctl status dnsmasq
is
dsnmasq.service
   Loaded: not-found (Reason: No such file or directory)
   Active: inactive (dead)
I don't know why. If i try
apt-get install dnsmasq
It says that the newest version is installed...
Another Problem is that in the installer and the repair bash I get this kind of warning:
/opt/pihole/updatecheck.sh: line 75: /usr/bin/pihole-FTL: Operation not permitted
/opt/pihole/updatecheck.sh: line 88: /usr/bin/pihole-FTL: Operation not permitted
And in other lines too.
The Output of
systemctl status pihole-FTL
is
   Loaded: loaded (/etc/init.d/pihole-FTL)
   Active: active (exited) since Fri 2019-04-26 11:12:33 EDT; 35s ago
  Process: 27728 ExecStop=/etc/init.d/pihole-FTL stop (code=exited, status=0/SUCCESS)
  Process: 27734 ExecStart=/etc/init.d/pihole-FTL start (code=exited, status=0/SUCCESS)
Apr 26 11:12:33 benti pihole-FTL[27734]: Not running
Apr 26 11:12:33 benti su[27761]: Successful su for pihole by root
Apr 26 11:12:33 benti su[27761]: + ??? root:pihole
Apr 26 11:12:33 benti su[27761]: pam_unix(su:session): session opened for user pihole by (uid=0)
Apr 26 11:12:33 benti pihole-FTL[27734]: sh: 1: /usr/bin/pihole-FTL: Operation not permitted
Apr 26 11:12:33 benti su[27761]: pam_unix(su:session): session closed for user pihole
Apr 26 11:12:33 benti systemd[1]: Started LSB: pihole-FTL daemon.
Help is appreciated
In Pi-Hole V4.0 and later, dnsmasq is embedded in pihole-FTL, and dnsmasq no longer runs as a separate process. The debug log will show dnsmasq as either failed or inactive. Process pihole-FTL should be shown running on port 53.
Has Pi-Hole previously worked with this installation, or has it never worked?
To check for processes running on ports used by Pi-Hole, run this command and post the output.
sudo netstat -nltup | grep 'Proto\|:53 \|:67 \|:80 \|:471'
Thanks for the quick reply.
Well that explains why its not running.
returns:
tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      28131/lighttpd
tcp6       0      0 :::80                   :::*                    LISTEN      28131/lighttpd
It has never worked in this setup.
Btw I rechecked the dnsmasq service and I got another output than before, because of a typo.
 dnsmasq.service - dnsmasq - A lightweight DHCP and caching DNS server
   Loaded: loaded (/lib/systemd/system/dnsmasq.service; disabled)
  Drop-In: /run/systemd/generator/dnsmasq.service.d
           └─50-dnsmasq-$named.conf, 50-insserv.conf-$named.conf
   Active: failed (Result: exit-code) since Fri 2019-04-26 10:51:03 EDT; 1h 21min ago
Apr 26 10:51:03 benti dnsmasq[10738]: dnsmasq: bad option at line 43 of /etc/dnsmasq.d/01-pihole.conf.save
Apr 26 10:51:03 benti systemd[1]: dnsmasq.service: control process exited, code=exited status=1
Apr 26 10:51:03 benti systemd[1]: Failed to start dnsmasq - A lightweight DHCP and caching DNS server.
Apr 26 10:51:03 benti systemd[1]: Unit dnsmasq.service entered failed state.
Apr 26 10:53:51 benti systemd[1]: Stopped dnsmasq - A lightweight DHCP and caching DNS server.
Just in case anyone wonders.
Remove the existing dnsmasq installation and this may resolve the problem:
sudo apt-get remove dnsmasq-base
I removed dnsmasq-base but it didn't change anything
Run the repair option to see if it fixes dnsmasq left overs:
pihole -r
Reboot after and post results for below ones again:
sudo systemctl status pihole-FTL -l
journalctl -u pihole-FTL
sudo netstat -nltup | grep 'Proto\|:53 \|:67 \|:80 \|:471[1-8] '
I did what you said and these are the results:
returns
pihole-FTL.service - LSB: pihole-FTL daemon
   Active: active (exited) since Fri 2019-04-26 14:39:34 EDT; 3min 54s ago
  Process: 238 ExecStart=/etc/init.d/pihole-FTL start (code=exited, status=0/SUCCESS)
Apr 26 14:39:34 benti systemd[1]: Starting LSB: pihole-FTL daemon...
Apr 26 14:39:34 benti pihole-FTL[238]: Not running
Apr 26 14:39:34 benti su[355]: Successful su for pihole by root
Apr 26 14:39:34 benti su[355]: + ??? root:pihole
Apr 26 14:39:34 benti su[355]: pam_unix(su:session): session opened for user pihole by (uid=0)
Apr 26 14:39:34 benti pihole-FTL[238]: sh: 1: /usr/bin/pihole-FTL: Operation not permitted
Apr 26 14:39:34 benti su[355]: pam_unix(su:session): session closed for user pihole
Apr 26 14:39:34 benti systemd[1]: Started LSB: pihole-FTL daemon.
returns
-- Logs begin at Fri 2019-04-26 14:39:34 EDT, end at Fri 2019-04-26 14:44:00 EDT. --
And
sudo netstat -nltup | grep 'Proto|:53 |:67 |:80 |:471[1-8] '
returns
tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      340/lighttpd
tcp6       0      0 :::80                   :::*                    LISTEN      340/lighttpd
sudo setcap CAP_NET_BIND_SERVICE,CAP_NET_RAW,CAP_NET_ADMIN+eip "$(which pihole-FTL)"
What does that do?
Its part of the init.d script:
less /etc/init.d/pihole-FTL
EDIT: Sets capabilities:
https://docs.pi-hole.net/ftldns/in-depth/#linux-capabilities
I tried it. I get no output from that.
I reran the repair thing and nothing changes, sadly.
I still get some warnings/errors like that:
Below, from the init.d script, is suppose to starts pihole-FTL as the "pihole" user (as designed):
su -s /bin/sh -c "/usr/bin/pihole-FTL" "$FTLUSER"
And below one will force it to run as the "root" user:
sudo su -s /bin/sh -c "/usr/bin/pihole-FTL" "root"
You could try run the latter one manually but be warned that the database file will probably change ownership to root !
pi@noads:~ $ stat /etc/pihole/pihole-FTL.db
Access: (0644/-rw-r--r--)  Uid: (  999/  pihole)   Gid: (  996/  pihole)
So I should try to run this:
EDIT:
Nvm. cant read :smiley:
Yeah, see if she starts without permission limitation's
It doesn't :confused:
arch
dpkg --print-architecture
dpkg --print-foreign-architectures
file /usr/bin/pihole-FTL
root@benti:~# arch
x86_64
root@benti:~# dpkg --print-architecture
amd64
root@benti:~# dpkg --print-foreign-architectures
root@benti:~# file
-bash: file: command not found
/usr/bin/pihole-FTL: ELF 64-bit LSB shared object, x86-64, version 1 (SYSV), dynamically linked, interpreter /lib64/l, for GNU/Linux 2.6.32, BuildID[sha1]=6bb2ee239d8e2558c54dcd10a3272a42038fcce8, not stripped
Looks all good.
Not sure.
Wait for a dev :roll_eyes:
