Hi there,
my Pi-hole stopped working all of a sudden. My DNS service is not running, and I am seeing the following error:
I am running my Pi-hole on a Raspberry Pi without Docker
https://tricorder.pi-hole.net/7JTdaUhY/
Thank you very much for providing help here
2022-09-02 04:07:03.978 654M] FATAL ERROR in dnsmasq core: failed to create listening socket for port 53: Address already in use
udp:127.0.0.1:53 is in use by connmand
You need to to stop/disable conmand.
I remember others encountered the issue as well, search for it in the forum.
Thank you very much for that hint! Loosely followed this guide to disabled the dns-proxy of connmand:
https://www.reddit.com/r/pihole/comments/por9uo/network_after_upgrade_to_bullseye/
changing connman start file /etc/systemd/system/multi-user.target.wants/connman.service
change from
ExecStart=/usr/sbin/connmand -n
to
ExecStart=/usr/sbin/connmand -n --nodnsproxy
reload config changes
systemctl daemon-reload
restart connman to free up port 53
systemctl restart connman.service
restart pihole-FTL
systemctl restart pihole-FTL.service
It is working again now!
