DNS Server is not running
would it be possible to run pihole on debian jessie (armel) with apache2? I went through the installation, the pihole interface on webserver is running, but the DNS and FTL Service
failed to start. Please see upload
https://tricorder.pi-hole.net/9e0fi0sq4w!
thank you very much
pihole-FTL does not seem to be running. Let's see what is running on the ports used by Pi-Hole and get the status of pihole-FTL. What is the output of these commands from the Pi terminal:
sudo netstat -nltup | grep 'Proto\|:53 \|:67 \|:80 \|:471'
thanks for your help
netstat -nltup | grep 'Proto|:53 |:67 |:80 |:471'
tcp6       0      0 :::80                   :::*                    LISTEN      975/apache2
â—Ź pihole-FTL.service - LSB: pihole-FTL daemon
   Loaded: loaded (/etc/init.d/pihole-FTL)
   Active: active (exited) since Do 2019-03-14 14:08:51 CET; 1h 8min ago
  Process: 5579 ExecStart=/etc/init.d/pihole-FTL start (code=exited, status=0/SUCCESS)
Mär 14 14:08:50 qnap-121 pihole-FTL[5579]: Not running
Mär 14 14:08:51 qnap-121 su[5606]: Successful su for pihole by root
Mär 14 14:08:51 qnap-121 su[5606]: + ??? root:pihole
Mär 14 14:08:51 qnap-121 su[5606]: pam_unix(su:session): session opened for user pihole by (uid=0)
Mär 14 14:08:51 qnap-121 systemd[1]: Started LSB: pihole-FTL daemon.
Mär 14 14:08:51 qnap-121 pihole-FTL[5579]: sh: 1: /usr/bin/pihole-FTL: not found
Mär 14 14:09:06 qnap-121 systemd[1]: Started LSB: pihole-FTL daemon.
i just ran this command:
pihole -up
it says:
/etc/.pihole/automated install/basic-install.sh: line 2358: /usr/bin/pihole-FTL: File or Directory not found!
I checked and the file is there!
sudo nano /etc/resolv.conf
edit nameserver 127.0.0.1 to nameserver 9.9.9.9 or your preferred third party DNS service, save and exit
Run pihole -r and select repair.
the output is:
[âś—] DNS service is NOT running
/opt/pihole/updatecheck.sh: Zeile 75: /usr/bin/pihole-FTL: Datei oder Verzeichnis nicht gefunden
/opt/pihole/updatecheck.sh: Zeile 88: /usr/bin/pihole-FTL: Datei oder Verzeichnis nicht gefunden
[i] The install log is located at: /etc/pihole/install.log
Update Complete!
Current Pi-hole version is v4.2.2
Current AdminLTE version is v4.2
/opt/pihole/version.sh: Zeile 19: /usr/bin/pihole-FTL: Datei oder Verzeichnis nicht gefunden
Invalid Option! Try 'pihole -v --help' for more information.
What is the output from
ls -lah /usr/bin/pihole-FTL
-rwxr-xr-x 1 root root 4,1M Mär 14 17:48 /usr/bin/pihole-FTL
file /usr/bin/pihole-FTL
arch
dpkg --print-architecture
EDIT:
dpkg --print-foreign-architectures
`file /usr/bin/pihole-FTL
/usr/bin/pihole-FTL: ELF 32-bit LSB shared object, ARM, EABI5 version 1 (SYSV), dynamically linked, interpreter /lib/ld-linux-armhf.so.3, for GNU/Linux 2.6.32, not stripped
arch
armv5tel
armel
"this command has no output"
Am not familiar with that architecture but it could be that you have the wrong binary for your arch.
It resembles other issues posted here before.
Wait if @DanSchaper knows more.
That's not a currently supported architecture. See https://docs.pi-hole.net/ftldns/compatibility/ for the list.
If you'd like to try and compile for your platform the instructions are on Install from source - Pi-hole documentation
i am sorry ... i will try to compile it
thank you very much for your help
thomas
short feddback:
I am using a Qnap Device (TS-121, 2 GHz CPU, 1 GB RAM) with armel Architecture and Debian 8 Jessie.
I compiled FTL DNS according to this doc Install from source - Pi-hole documentation and it is working without any problems now.
Thanks again for your help and this great piece of software!
Kind regards
Thomas
