DNS resolving but Pi-hole not doing it
#1
Pi hole should block ad domains based on the blacklists
Ads are not blocked, all sites resolve dns.
rxejj7muve
Looking around the forum I think this might be an issue with my DNSmasque but that gets a checkmark on the debugging from the pi-hole, so now I don’t know what to think
I know my router is using the pi hole as the dns resolver, and every system that I run an ipconfig or an isconfig on shows that the correct ip address is the dns for that device, and I have the blacklists installed as i have 132,000 domains there, but there are no queries to the pi-hole itself, they all seem to be resolving somehow.
note that I am running this on an ubuntu server.
I have searched and searched but none of the solutions I have found have seemed to solve this issue.
#2
On the Pi-hole device can you run the following commands:
sudo systemctl status --full --no-pager dnsmasq.service
cat /etc/resolv.conf
The debug log shows that dnsmasq is not running on the Pi-hole device, but there is a resolver running. dig queries to 127.0.0.1 fail but queries to 192.168.0.2 return an answer.
#3
#4
dnsmasq could not start because there is another DNS resolver in operation. What is the output from sudo ss tlpn | grep 53?
#5
Error: an inet prefix is expected rather than “tlpn”
Cannot parse dst/src address
#6
Sorry, I left off the -, try sudo ss -tlpnax | grep 53 instead.
#7
I think this is all of it:
#8
That shows that systemd-resolved and named have control over port 53 on your system. @RamSet What was the process of clearing out systemd-resolved from having control?
#9
Would this work, do you think?
sudo systemctl disable systemd-resolved.service
sudo service systemd-resolved stop
#10
Found it :slightly_smiling_face:
edit /etc/systemd/resolved.conf and add this line:
DNSStubListener=no
This will switch off binding to port 53.
Restarted the system and all is good!
Thanks very much for your help @DanSchaper
