Description:
I have installed PiHole on RP0w, changed DNS settings on my router to make all clients resolve domains from it. After that, I wanted to install PiVPN to be able to get the max of it to the outer network as well, but it failed to connect for some reason. So, I decided to remove PiVPN and find a solution later. Long story short, the internet didn't work afterward.
I checked the debug report and I found out that PiHole couldn't resolve domains for some reason! while it can resolve
[✓] azurezerohentai.blogspot.sk is 0.0.0.0 via localhost (127.0.0.1)
[✗] Failed to resolve azurezerohentai.blogspot.sk via Pi-hole (192.168.0.124)
[✓] doubleclick.com is 172.217.16.78 via a remote, public DNS server (8.8.8.8)
[✓] tubaolic.com is :: via localhost (::1)
[✗] Failed to resolve tubaolic.com via Pi-hole (2a02:8109:8340:5e90:a554:d2d0:372f:2a71)
[✗] Failed to resolve doubleclick.com via a remote, public DNS server (2001:4860:4860::8888)
Possible solutions tried:
pi@raspberrypi:~ $ dig google.com @127.0.0.1
; <<>> DiG 9.11.5-P4-5.1+deb10u2-Raspbian <<>> google.com @127.0.0.1
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 62474
;google.com. IN A
google.com. 231 IN A 216.58.213.238
;; Query time: 1 msec
;; WHEN: Thu Sep 03 12:03:37 CEST 2020
;; MSG SIZE rcvd: 55
pi@raspberrypi:~ $ dig google.com @192.168.0.124
; <<>> DiG 9.11.5-P4-5.1+deb10u2-Raspbian <<>> google.com @192.168.0.124
multiple restart
pihole -r
changed the /etc/resolv.conf to 8.8.8.8 instead of 127.0.0.1
token is: https://tricorder.pi-hole.net/bcjcpzh2g8
