DNS resolution is currently unavailable - but - everything works as expected
I run Pi-hole in a docker environment on Ubuntu 22.04 LTS with Portainer. Additionally I have the cloudflared-container running (in a separate docker network (IP: 10.0.0.5)). I expect the pihole -g command to run smoothly and with our errors.
Docker Compose File
version: "3"
services:
  pihole:
    container_name: pihole
    image: pihole/pihole:latest
    ports:
      - "53:53/tcp"
      - "53:53/udp"
      - "67:67/udp"
    environment:
      TZ: 'Europe/Berlin'
      # WEBPASSWORD: 'set a secure password here or it will be random'
    volumes:
      - './etc-pihole/:/etc/pihole/'
      - './etc-dnsmasq.d/:/etc/dnsmasq.d/'
    # Recommended but not required (DHCP needs NET_ADMIN)
    #   https://github.com/pi-hole/docker-pi-hole#note-on-capabilities
    labels:
      - "traefik.enable=true"
      - "traefik.http.routers.pihole.rule=Host(`pihole.internal.local`)"
      - "traefik.http.services.pihole.loadbalancer.server.port=80"
      - "traefik.http.routers.pihole.entrypoints=web"
      # 53/udp
      - "traefik.udp.routers.53-udp.entrypoints=53-udp"
      - "traefik.udp.routers.53-udp.service=pihole-53-udp"
      - "traefik.udp.services.pihole-53-udp.loadbalancer.server.port=53"
  # 53/tcp
      - "traefik.tcp.routers.53-tcp.rule=HostSNI(`*`)"
      - "traefik.tcp.routers.53-tcp.entrypoints=53-tcp"
      - "traefik.tcp.routers.53-tcp.service=pihole-53-tcp"
      - "traefik.tcp.services.pihole-53-tcp.loadbalancer.server.port=53"
    cap_add:
      - NET_ADMIN
    restart: unless-stopped
    networks:
      web: # communication with Traefik
      pihole_net: # communication with cloudflared
        ipv4_address: 10.0.0.3
# Cloudflared for DoH
  cloudflared:
    container_name: cloudflared
    image: visibilityspots/cloudflared:latest
    networks:
      pihole_net:
        ipv4_address: 10.0.0.5
networks:
    web:
      external: true
    pihole_net:
      driver: bridge
      ipam:
       config:
        - subnet: 10.0.0.0/29
Instead the pihole -g command fails with the error:
[āœ—] DNS resolution is currently unavailable
  [i] Time until retry: 113^C
  [i] User-abort detected
  [āœ“] Cleaning up stray matter
  [āœ“] FTL is listening on port 53
     [āœ“] UDP (IPv4)
     [āœ“] TCP (IPv4)
     [āœ“] UDP (IPv6)
     [āœ“] TCP (IPv6)
  [āœ“] Pi-hole blocking is enabled
https://tricorder.pi-hole.net/xG82kCxx/
Thanks in advance,
Benedict
How are you running pihole -g? Does the same error happen if you use the admin page Update Gravity feature?
http://pi.hole/admin/gravity.php
I am running pihole -g via docker execute and it shows the same errors as when running it via the admin page Update Gravity feature!
the times this has happened to me have been the times where the pihole itself doesn't have any internet access at all.
I find it happens when I go in and I set the static IP in linux and then I forget to add a DNS in the static IP configuration.
Do you have access to a webbrowser or even ping? You could test a domain with ping and see if you get anything back.
I'd try something like
sudo ping google.com
and see if it can reach anything outbound.
This is likely the issue. The container running Pi-hole looks like it has access to the web network that traefik is monitoring and pihole_net that is a private bridge to connect the pihole and cloudflared containers. I don't see where either of these containers have access outside of that private bridge 10.x/29 network.
Enough mistakes while setting it up myself and sometimes I can answer questions correctly!
Thanks for your ideas. :pray:
The web network, that is monitored by traefik, has access to the internet.
Interestingly I can ping google.com from the pihole-container but not from the cloudflared-container. Is that an expected behaviour?
That's my Netplan config
network:
    version: 2
    renderer: networkd
    ethernets:
        enp0s4:
            dhcp4: true
            nameservers:
             #addresses: [10.32.8.9, 1.1.1.1, 8.8.8.8]
              addresses:
              - 127.0.0.1
Should I configure a public DNS-server there, so that my Docker host system (Ubuntu 22.04 LTS) has internet access? Ubuntu runs virtualized on TrueNAS Core (bhyve) - in TrueNAS the only configured DNS-server is the IP of pihole.
What I don't really get is: Why is everything still working as expected? My router broadcasts pihole as the DNS-server to all devices and I can browse the web without any problems.
I honestly have no advice for you, seems like a rather complex setup with docker composed of multiple networks on a virtualized Ubuntu hosted on TrueNAS.
Thank you anyways.
As it's working quite properly (Thanks for your great work btw) I think I will leave it unchanged until the next bigger system upgrade.
