If you are Experiencing issues with a Pi-hole install that has non-standard elements (e.g you are using nginx instead of lighttpd, or there is some other aspect of your install that is customised) - please use the [Community Help] category.
DNS Resolution occurs quickly.
Getting unresolved DNS issues on all devices. Even for simple requests like Google or things definitely not a block list.
tricorder.pi-hole.net/uy6mdnwro1
BTW it wouldn't let me submit this because it said I couldn't submit more that 5 links as a new user. Realized this is stemming from your template. I had only provided 1 link via debug token.
That's my fault on the logs. I reconfigured the raspberry Pi based on other user suggestions on forums. However, because of the issues since upgrading, I can't really leave it as the DHCP source for long.
If you still do, please provide a debug token where Pi-hole is actually receiving DNS; and also please comply with jfb's request for log file samples for failing domain resolutions.
No it means that it doesnt work. So I can leave it as the DNS resource for the house very long I need to wait until the evening when no one is working.
