DNS requests stop resolving for no foreseeable reason
#1
DNS to always resolve
DNS requests stop resolving for no reason.
Side note: This has happened before, about 2 months ago, at that time i updated all of the PI linux (apt-get upgrade) apps, and reinstalled Pihole. But there has to be a logical answer why DNS requests stop resolving.
fstom1x43j
#3
Nothing appears wrong in your debug log. But there are some possible avenues to explore:
  1. You use DNSSEC. If the time on your Pi drifts significantly, this may cause problems with DNSSEC.
  2. If you are tight on SD card space, logs could grow over time and fill up your card.
#6
If it is time drift causing the problem it is easy to install ntp on your Pi and let it keep your clock correct.
#7
All, thanks for replies.
I’ve had this issue before, when i wasn’t using DNSSEC.
I’ve got enough space free on the PI SD card, about 24GB free. So far i’ve changed the NTP servers to be closer to me.
Some more info, when the client side (Windows pc, tablet, etc) DNS resolution fails, i can SSH into the PI and notice i cannot ping to say google.ca, but i can ping fine by IP.
I may consider rebuilding my PI with Raspbian Stretch (current is Jessie). But i just want some answer as to whats causing this. Rebuilding shouldn’t be the answer.
Thanks all.
#8
Another possibility - a hardware issue. Power supply (inadequate current), degrading SD card, physical damage to the SD card or insertion pins, etc.
#9
Wouldn’t any of that crash the PI as a whole? It’s been up for weeks without a crash.
#10
This was happening constantly to me on an older setup with a Raspberry Pi3 that was running also ADS-B. Now I got a dedicated OrangePi One (Debian Stretch), and installed only the PiHole on it. In an hour of working I had the same issues. Stopped resolving, multiple F5 eventually made that site resolve.
This is the latest FTL 4.0. Before (Pi) I was on the beta FTL branch.
#11
Soooooo did you resolve it at all or what?
What triggered this issue? Did you ever find out?
#12
I did not find out why is doing that. Almost like is going to sleep.
#13
Did you take a look at the logs on that device and see if there were any clues in there?
/var/log/syslog
/var/log/pihole-FTL.log
#14
Nothing, new clues.
I had the DNS resolutions quit at 3pm my time, up to 3:05pm. Here are the relevant logs
Pihole-FTL Log:
[2018-10-23 00:07:26.455] Notice: Increasing domains struct size from 10000 to 11000
[2018-10-23 12:00:02.262] Notice: Increasing overTime struct size from 1100 to 1200
Thats all there was.
Syslog for the relevant time and date.
Oct 23 14:40:01 pihole CRON[711]: (root) CMD (   PATH="$PATH:/usr/local/bin/" pihole updatechecker local)
Oct 23 14:50:01 pihole CRON[732]: (root) CMD (   PATH="$PATH:/usr/local/bin/" pihole updatechecker local)
Oct 23 15:00:01 pihole CRON[754]: (root) CMD (   PATH="$PATH:/usr/local/bin/" pihole updatechecker local)
Oct 23 15:03:52 pihole systemd[1]: Starting Session c80 of user pi.
Oct 23 15:03:52 pihole systemd[1]: Started Session c80 of user pi.
Oct 23 15:07:45 pihole systemd[1]: Starting Session c81 of user pi.
Oct 23 15:07:45 pihole systemd[1]: Started Session c81 of user pi.
Oct 23 15:09:01 pihole CRON[1100]: (root) CMD (  [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean)
Oct 23 15:10:01 pihole CRON[1150]: (root) CMD (   PATH="$PATH:/usr/local/bin/" pihole updatechecker local)
Oct 23 15:16:34 pihole systemd[1]: Starting Session c82 of user pi.
Oct 23 15:16:34 pihole systemd[1]: Started Session c82 of user pi.
Oct 23 15:17:01 pihole CRON[1376]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
#15
What were the symptoms when this happened? And what did you do to get DNS resolution working again?
The next time this happens, run a debug log while the problem exists. You may not be able to upload it then, but take a look through it and see if an errors are shown.
#16
Almost all of my open apps quit on me, like Skype, Youtube stopped playing, and i couldn’t ping anything by DNS names.
I waited about 5 minutes and everything resumed to work.
#17
Since you’re considering upgrading your Raspbian to Stretch, now is probably a good time. Export your Pi-Hole settings with teleporter, then they are available for importing on your new installation.
#18
Ok i’ll give Stretch a shot and see what happens.
Pi1 B+ should be powerful enough to run PiHole? I don’t see a high RAM or CPU usage at all.
#19
This is roughly equivalent to a Pi Zero (slower clock speed) and a Pi Zero does nicely on a home network.
#20
Just to bring an update: I took out the DNS IP from the router and put in in my PC network settings - the settings accepted just one IP. My router doesn’t, so one IP was external.
No more “glitches”.
#21
Guys, it happened again. Fresh install of Raspbian Stretch, fresh install of pihole.
below is the log,
This process collects information from your Pi-hole, and optionally uploads it to a unique and random directory on tricorder.pi-hole.net.
The intent of this script is to allow users to self-diagnose their installations.  This is accomplished by running tests against our software and providing the user with links to FAQ articles when a problem is detected.  Since we are a small team and Pi-hole has been growing steadily, it is our hope that this will help us spend more time on development.
*** [ INITIALIZING ]
[i] 2018-11-08:22:23:49 debug log has been initialized.
[i] Core: v4.0 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Branch: master
[i] Commit: v4.0-0-gddbdb51
[i] Web: v4.0 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Branch: master
[i] Commit: v4.0-0-gaf8c926
[✓] FTL: v4.0
*** [ DIAGNOSING ]: dnsmasq version
[i] 340:
[i] 1.4.45
[i] 7.0.30
[✓] Raspbian GNU/Linux 9 (stretch)
*** [ DIAGNOSING ]: SELinux
[i] SELinux not detected
*** [ DIAGNOSING ]: Processor
[✓] armv6l
   192.168.0.4/24 matches the IP found in /etc/pihole/setupVars.conf
   fe80::814a:5856:ef1b:cf8f does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
[i] Default IPv4 gateway: 192.168.0.1
   * Pinging 192.168.0.1...
[✓] Gateway responded.
[i] Default IPv6 gateway: eth0
   * Pinging eth0...
*:22 sshd (IPv4)
*:22 sshd (IPv6)
*:80 lighttpd (IPv4)
*:80 lighttpd (IPv6)
*:53 pihole-FTL (IPv4)
*:53 pihole-FTL (IPv6)
127.0.0.1:4711 pihole-FTL (IPv4)
[::1]:4711 pihole-FTL (IPv6)
[✓] www.e-zeeinternet.com is 0.0.0.0 via localhost (127.0.0.1)
[✓] www.e-zeeinternet.com is 0.0.0.0 via Pi-hole (192.168.0.4)
[✓] doubleclick.com is 172.217.0.238 via a remote, public DNS server (8.8.8.8)
[✗] dnsmasq daemon is inactive
[✓] lighttpd daemon is active
    PIHOLE_INTERFACE=eth0
    IPV4_ADDRESS=192.168.0.4/24
    IPV6_ADDRESS=
    QUERY_LOGGING=true
    INSTALL_WEB_SERVER=true
    INSTALL_WEB_INTERFACE=true
    LIGHTTPD_ENABLED=true
    DNSMASQ_LISTENING=single
    PIHOLE_DNS_1=149.112.112.112
    PIHOLE_DNS_2=1.1.1.1
    DNS_FQDN_REQUIRED=true
    DNS_BOGUS_PRIV=true
    DNSSEC=true
    CONDITIONAL_FORWARDING=true
    CONDITIONAL_FORWARDING_IP=192.168.0.1
    CONDITIONAL_FORWARDING_DOMAIN=gabriclan.ca
    CONDITIONAL_FORWARDING_REVERSE=0.168.192.in-addr.arpa
[✓] Block page X-Header: X-Pi-hole: A black hole for Internet advertisements.
[✓] Web interface X-Header: X-Pi-hole: The Pi-hole Web interface is working!
-rw-r--r-- 1 root root 2940895 Nov  4 03:43 /etc/pihole/gravity.list
   0.0.0.0
   0.r.msn.com
   0.start.bz
   00.creativecdn.com
   zzz.clickbank.net
   zzzezeroe.fr
   zzzpooeaz-france.com
   zzzrtrcm2.com
-rw-r--r-- 1 root root 381 Oct 25 23:35 /etc/pihole/adlists.list
-rw-r--r-- 1 root root 0 Nov  2 04:53 /etc/pihole/blacklist.txt
-rw-r--r-- 1 root root 39 Nov  4 03:43 /etc/pihole/local.list
   192.168.0.4 pihole
   192.168.0.4 pi.hole
-rw-r--r-- 1 root root 234 Oct 25 23:44 /etc/pihole/logrotate
   /var/log/pihole.log {
   	su root root
   	daily
   	copytruncate
   	rotate 5
   	compress
   	delaycompress
   	notifempty
   	nomail
   /var/log/pihole-FTL.log {
   	su root root
   	weekly
   	copytruncate
   	rotate 3
   	compress
   	delaycompress
   	notifempty
   	nomail
-rw-r--r-- 1 root root 999 Nov  2 04:53 /etc/pihole/whitelist.txt
   clients4.google.com
   clients2.google.com
   s.youtube.com
   video-stats.l.google.com
   android.clients.google.com
   www.msftncsi.com
   outlook.office365.com
   products.office.com
   c.s-microsoft.com
   i.s-microsoft.com
   login.live.com
   dl.delivery.mp.microsoft.com
   geo-prod.do.dsp.mp.microsoft.com
   displaycatalog.mp.microsoft.com
   s.gateway.messenger.live.com
   ui.skype.com
   pricelist.skype.com
   apps.skype.com
   m.hotmail.com
   sa.symcb.com
   s1.symcb.com
   s2.symcb.com
   s3.symcb.com
   s4.symcb.com
   s5.symcb.com
   officeclient.microsoft.com
   services.sonarr.tv
   skyhook.sonarr.tv
   download.sonarr.tv
   apt.sonarr.tv
   forums.sonarr.tv
   placehold.it
   placeholdit.imgix.net
   widget-cdn.rpxnow.com
   imagesak.secureserver.net
   delivery.vidible.tv
   img.vidible.tv
   videos.vidible.tv
   edge.api.brightcove.com
   cdn.vidible.tv
   dev.virtualearth.net
   ecn.dev.virtualearth.net
   t0.ssl.ak.dynamic.tiles.virtualearth.net
   t0.ssl.ak.tiles.virtualearth.net
   connectivitycheck.android.com
   clients3.google.com
   connectivitycheck.gstatic.com
   msftncsi.com
   ipv6.msftncsi.com
-rw-r--r-- 1 root root 1810 Nov  7 20:52 /etc/dnsmasq.d/01-pihole.conf
   localise-queries
   no-resolv
   cache-size=10000
   log-queries=extra
   local-ttl=2
   log-async
   server=149.112.112.112
   server=1.1.1.1
   domain-needed
   bogus-priv
   dnssec
   trust-anchor=.,19036,8,2,49AAC11D7B6F6446702E54A1607371607A1A41855200FD2CE1CDDE32F24E8FB5
   trust-anchor=.,20326,8,2,E06D44B80B8F1D39A95C0B0D7C65D08458E880409BBC683457104237C7F8EC8D
   interface=eth0
   server=/gabriclan.ca/192.168.0.1
   server=/0.168.192.in-addr.arpa/192.168.0.1
-rw-r--r-- 1 root root 3027 Oct 25 23:44 /etc/lighttpd/lighttpd.conf
   server.modules = (
   	"mod_access",
   	"mod_accesslog",
   	"mod_auth",
   	"mod_expire",
   	"mod_compress",
   	"mod_redirect",
   	"mod_setenv",
   	"mod_rewrite"
   server.error-handler-404    = "pihole/index.php"
   server.pid-file             = "/var/run/lighttpd.pid"
   accesslog.filename          = "/var/log/lighttpd/access.log"
   accesslog.format            = "%{%s}t|%V|%r|%s|%b"
   compress.cache-dir          = "/var/cache/lighttpd/compress/"
   compress.filetype           = ( "application/javascript", "text/css", "text/html", "text/plain" )
   include_shell "/usr/share/lighttpd/create-mime.assign.pl"
' 2>/dev/null"
   $HTTP["url"] =~ "^/admin/" {
           "X-Frame-Options" => "DENY"
       $HTTP["url"] =~ ".ttf$" {
        url.access-deny = ("")
-rw-r--r-- 1 root root 1496 Oct 25 23:44 /etc/cron.d/pihole
   43 3   * * 7   root    PATH="$PATH:/usr/local/bin/" pihole updateGravity
   00 00   * * *   root    PATH="$PATH:/usr/local/bin/" pihole flush once quiet
   */10 *  * * *   root    PATH="$PATH:/usr/local/bin/" pihole updatechecker local
   49 15  * * *   root    PATH="$PATH:/usr/local/bin/" pihole updatechecker remote
   @reboot root    PATH="$PATH:/usr/local/bin/" pihole updatechecker remote reboot
-rw-r--r-- 1 www-data www-data 1261 Nov  8 00:00 /var/log/lighttpd/error.log
   2018-11-05 06:25:06: (server.c.1534) logfiles cycled UID = 0 PID = 11607
   2018-11-06 06:26:39: (server.c.1828) server stopped by UID = 0 PID = 1
   2018-11-06 06:27:06: (log.c.217) server started
   2018-11-06 10:17:35: (log.c.217) server started
   2018-11-06 23:28:07: (log.c.217) server started
   2018-11-07 20:42:34: (server.c.1828) server stopped by UID = 0 PID = 1
   2018-11-07 20:43:00: (log.c.217) server started
   2018-11-07 22:35:37: (server.c.1828) server stopped by UID = 0 PID = 1
   2018-11-07 22:36:06: (log.c.217) server started
   2018-11-07 22:41:07: (server.c.1828) server stopped by UID = 0 PID = 1
   2018-11-07 22:41:40: (log.c.217) server started
   2018-11-07 22:50:42: (server.c.1828) server stopped by UID = 0 PID = 1
   2018-11-07 22:51:11: (log.c.217) server started
   2018-11-07 22:57:24: (server.c.1828) server stopped by UID = 0 PID = 1
   2018-11-07 22:57:55: (log.c.217) server started
   2018-11-07 23:01:34: (server.c.1828) server stopped by UID = 0 PID = 1
   2018-11-07 23:02:01: (log.c.217) server started
   2018-11-07 23:53:51: (server.c.1828) server stopped by UID = 0 PID = 1
   2018-11-07 23:54:18: (log.c.217) server started
   2018-11-07 23:59:39: (server.c.1828) server stopped by UID = 0 PID = 1
   2018-11-08 00:00:07: (log.c.217) server started
-rw-r--r-- 1 pihole pihole 3920 Nov  8 22:16 /var/log/pihole-FTL.log
   [2018-11-08 00:00:11.942] ########## FTL started! ##########
   [2018-11-08 00:00:11.943] FTL branch:
   [2018-11-08 00:00:11.943] FTL version: v4.0
   [2018-11-08 00:00:11.944] FTL commit: 8493df4
   [2018-11-08 00:00:11.944] FTL date: 2018-08-05 13:40:30 -0700
   [2018-11-08 00:00:11.944] FTL user: pihole
   [2018-11-08 00:00:11.944] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
   [2018-11-08 00:00:11.945]    SOCKET_LISTENING: only local
   [2018-11-08 00:00:11.945]    AAAA_QUERY_ANALYSIS: Show AAAA queries
   [2018-11-08 00:00:11.945]    MAXDBDAYS: max age for stored queries is 365 days
   [2018-11-08 00:00:11.946]    RESOLVE_IPV6: Resolve IPv6 addresses
   [2018-11-08 00:00:11.946]    RESOLVE_IPV4: Resolve IPv4 addresses
   [2018-11-08 00:00:11.946]    DBINTERVAL: saving to DB file every minute
   [2018-11-08 00:00:11.947]    DBFILE: Using /etc/pihole/pihole-FTL.db
   [2018-11-08 00:00:11.947]    MAXLOGAGE: Importing up to 24.0 hours of log data
   [2018-11-08 00:00:11.947]    PRIVACYLEVEL: Set to 0
   [2018-11-08 00:00:11.948]    IGNORE_LOCALHOST: Show queries from localhost
   [2018-11-08 00:00:11.948]    BLOCKINGMODE: Null IPs for blocked domains
   [2018-11-08 00:00:11.948]    REGEX_DEBUGMODE: Inactive
   [2018-11-08 00:00:11.949] Finished config file parsing
   [2018-11-08 00:00:11.960] Compiled 0 Regex filters and 49 whitelisted domains in 11.0 msec (0 errors)
   [2018-11-08 00:00:12.014] Database successfully initialized
   [2018-11-08 00:00:12.031] Notice: Increasing queries struct size from 0 to 10000
   [2018-11-08 00:00:12.032] Notice: Increasing domains struct size from 0 to 1000
   [2018-11-08 00:00:12.032] Notice: Increasing clients struct size from 0 to 10
   [2018-11-08 00:00:12.032] New forward server: 1.0.0.1 (0/0)
   [2018-11-08 00:00:12.033] Notice: Increasing forwarded struct size from 0 to 4
   [2018-11-08 00:00:12.033] Notice: Increasing overTime struct size from 0 to 100
   [2018-11-08 00:00:12.033] New forward server: 1.1.1.1 (1/4)
   [2018-11-08 00:00:12.186] New forward server: 192.168.0.1 (2/4)
   [2018-11-08 00:00:12.256] Notice: Increasing queries struct size from 10000 to 20000
   [2018-11-08 00:00:12.285] Notice: Increasing overTime struct size from 100 to 200
   [2018-11-08 00:00:12.288] New forward server: 149.112.112.112 (3/4)
   [2018-11-08 00:00:12.289] New forward server: 84.200.70.40 (4/4)
   [2018-11-08 00:00:12.289] Notice: Increasing forwarded struct size from 4 to 8
   [2018-11-08 00:00:12.290] New forward server: 8.8.4.4 (5/8)
   [2018-11-08 00:00:12.290] New forward server: 8.8.8.8 (6/8)
   [2018-11-08 00:00:12.291] New forward server: 4.2.2.2 (7/8)
   [2018-11-08 00:00:12.303] Imported 11803 queries from the long-term database
   [2018-11-08 00:00:12.304]  -> Total DNS queries: 11803
   [2018-11-08 00:00:12.305]  -> Cached DNS queries: 1299
   [2018-11-08 00:00:12.305]  -> Forwarded DNS queries: 10478
   [2018-11-08 00:00:12.305]  -> Exactly blocked DNS queries: 2
   [2018-11-08 00:00:12.306]  -> Unknown DNS queries: 24
   [2018-11-08 00:00:12.306]  -> Unique domains: 19
   [2018-11-08 00:00:12.306]  -> Unique clients: 5
   [2018-11-08 00:00:12.306]  -> Known forward destinations: 8
   [2018-11-08 00:00:12.307] Successfully accessed setupVars.conf
   [2018-11-08 00:00:12.360] PID of FTL process: 515
   [2018-11-08 00:00:12.361] Listening on port 4711 for incoming IPv4 telnet connections
   [2018-11-08 00:00:12.362] Listening on port 4711 for incoming IPv6 telnet connections
   [2018-11-08 00:00:12.363] Listening on Unix socket
   [2018-11-08 00:00:12.368] Compiled 0 Regex filters and 49 whitelisted domains in 0.8 msec (0 errors)
   [2018-11-08 00:00:12.389] /etc/pihole/black.list: parsed 0 domains (took 0.1 ms)
   [2018-11-08 00:00:14.947] /etc/pihole/gravity.list: parsed 126723 domains (took 2555.3 ms)
   [2018-11-08 09:10:09.116] Notice: Increasing overTime struct size from 200 to 300
   [2018-11-08 20:02:07.880] Notice: Increasing domains struct size from 1000 to 2000
   [2018-11-08 22:16:44.356] Notice: Increasing clients struct size from 10 to 20
*** [ DIAGNOSING ]: Locale
    LANG=en_US.UTF-8
-rw-r--r-- 1 pihole pihole 8257074 Nov  8 22:25 /var/log/pihole.log
   -----head of pihole.log------
   Nov  8 00:00:12 dnsmasq[515]: started, version pi-hole-2.79 cachesize 10000
   Nov  8 00:00:12 dnsmasq[515]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP no-conntrack ipset auth DNSSEC loop-detect inotify
   Nov  8 00:00:12 dnsmasq[515]: DNSSEC validation enabled
   Nov  8 00:00:12 dnsmasq[515]: warning: failed to change owner of /var/log/pihole.log: Operation not permitted
   Nov  8 00:00:12 dnsmasq[515]: using nameserver 1.1.1.1#53
   Nov  8 00:00:12 dnsmasq[515]: using nameserver 149.112.112.112#53
   Nov  8 00:00:12 dnsmasq[515]: read /etc/hosts - 5 addresses
   Nov  8 00:00:12 dnsmasq[515]: read /etc/pihole/local.list - 2 addresses
   Nov  8 00:00:12 dnsmasq[515]: read /etc/pihole/black.list - 0 addresses
   Nov  8 00:00:14 dnsmasq[515]: read /etc/pihole/gravity.list - 253446 addresses
   Nov  8 00:00:26 dnsmasq[515]: 1 127.0.0.1/60209 query[A] 2.debian.pool.ntp.org from 127.0.0.1
   Nov  8 00:00:26 dnsmasq[515]: 1 127.0.0.1/60209 forwarded 2.debian.pool.ntp.org to 1.1.1.1
   Nov  8 00:00:26 dnsmasq[515]: 1 127.0.0.1/60209 forwarded 2.debian.pool.ntp.org to 149.112.112.112
   Nov  8 00:00:26 dnsmasq[515]: 2 127.0.0.1/60209 query[AAAA] 2.debian.pool.ntp.org from 127.0.0.1
   Nov  8 00:00:26 dnsmasq[515]: 2 127.0.0.1/60209 forwarded 2.debian.pool.ntp.org to 1.1.1.1
   Nov  8 00:00:26 dnsmasq[515]: 2 127.0.0.1/60209 forwarded 2.debian.pool.ntp.org to 149.112.112.112
   Nov  8 00:00:26 dnsmasq[515]: * 127.0.0.1/60209 dnssec-query[DS] org to 1.1.1.1
   Nov  8 00:00:26 dnsmasq[515]: * 127.0.0.1/60209 dnssec-query[DNSKEY] . to 1.1.1.1
#22
Your debug log again is normal.
#23
Where are some other places i could look to see whats happening?
