Multiple times a day, devices on my network stop being able to load web sites. When this occurs, I'm also unable to ping domains, but pinging IPs works fine. I believe what's happening is that DNS resolution stops working. I have a Raspberry Pi running Pi-hole taking care of DNS for my network. Restarting the Raspberry Pi is usually required to resolve this situation, though sometimes it solves itself within a few minutes. This has been happening since around the time I installed Pi-Hole v5.15.
When I tailed pihole.log, I noticed that I stop seeing "reply" log lines and instead see lots of "query" and "forwarded" log lines.
Before problem occurred:
Mar 26 13:32:35: query[HTTPS] api-partner.spotify.com from 10.0.1.16
Mar 26 13:32:35: forwarded api-partner.spotify.com to 208.67.220.220
Mar 26 13:32:35: query[A] api-partner.spotify.com from 10.0.1.16
Mar 26 13:32:36: forwarded api-partner.spotify.com to 208.67.220.220
Mar 26 13:32:36: reply api-partner.spotify.com is NODATA
Mar 26 13:32:36: reply api-partner.spotify.com is <CNAME>
Mar 26 13:32:36: reply partners.wg.spotify.com is <CNAME>
Mar 26 13:32:36: reply edge-web.dual-gslb.spotify.com is 35.186.224.25
Mar 26 13:32:36: query[HTTPS] postimg.cc from 10.0.1.16
Mar 26 13:32:36: forwarded postimg.cc to 208.67.220.220
Mar 26 13:32:36: query[A] postimg.cc from 10.0.1.16
Mar 26 13:32:36: reply postimg.cc is NODATA
Mar 26 13:32:36: reply postimg.cc is 46.229.175.90
Mar 26 13:32:36: query[HTTPS] postimgs.org from 10.0.1.16
Mar 26 13:32:36: forwarded postimgs.org to 208.67.220.220
Mar 26 13:32:36: query[A] postimgs.org from 10.0.1.16
Mar 26 13:32:36: reply postimgs.org is NODATA
Mar 26 13:32:36: reply postimgs.org is 104.21.43.29
Mar 26 13:32:36: reply postimgs.org is 172.67.216.170
Mar 26 13:32:36: query[HTTPS] i.postimg.cc from 10.0.1.16
Mar 26 13:32:36: forwarded i.postimg.cc to 208.67.220.220
Mar 26 13:32:38: query[HTTPS] i.postimg.cc from 10.0.1.16
Mar 26 13:32:38: forwarded i.postimg.cc to 208.67.222.222
Mar 26 13:32:38: forwarded i.postimg.cc to 208.67.220.220
Mar 26 13:32:38: reply i.postimg.cc is NODATA
While problem was occurring:
Mar 26 13:32:54: query[A] czfe58-front01-iad01.transport.home.nest.com from 10.0.0.4
Mar 26 13:32:54: forwarded czfe58-front01-iad01.transport.home.nest.com to 208.67.222.222
Mar 26 13:32:54: forwarded czfe58-front01-iad01.transport.home.nest.com to 208.67.220.220
Mar 26 13:32:54: query[AAAA] czfe58-front01-iad01.transport.home.nest.com from 10.0.0.4
Mar 26 13:33:09: query[HTTPS] api.mixpanel.com from 10.0.1.2
Mar 26 13:33:09: forwarded api.mixpanel.com to 208.67.222.222
Mar 26 13:33:09: query[A] api.mixpanel.com from 10.0.1.2
Mar 26 13:33:09: gravity blocked api.mixpanel.com is 0.0.0.0
Mar 26 13:33:10: query[HTTPS] api.mixpanel.com from 10.0.1.2
Mar 26 13:33:10: forwarded api.mixpanel.com to 208.67.222.222
Mar 26 13:33:10: forwarded api.mixpanel.com to 208.67.220.220
Mar 26 13:33:14: query[HTTPS] apps.mzstatic.com from 10.10.10.205
Mar 26 13:33:14: forwarded apps.mzstatic.com to 208.67.222.222
Mar 26 13:33:14: query[A] apps.mzstatic.com from 10.10.10.205
Mar 26 13:33:15: query[HTTPS] apps.mzstatic.com from 10.10.10.205
Mar 26 13:33:15: forwarded apps.mzstatic.com to 208.67.222.222
Mar 26 13:33:15: forwarded apps.mzstatic.com to 208.67.220.220
Mar 26 13:33:15: query[A] apps.mzstatic.com from 10.10.10.205
Mar 26 13:33:18: query[A] czfe58-front01-iad01.transport.home.nest.com from 10.0.0.4
Mar 26 13:33:18: forwarded czfe58-front01-iad01.transport.home.nest.com to 208.67.222.222
Mar 26 13:33:18: query[AAAA] czfe58-front01-iad01.transport.home.nest.com from 10.0.0.4
Mar 26 13:33:26: query[AAAA] hermes-prd.sn.tesla.services from 10.10.10.105
Mar 26 13:33:26: forwarded hermes-prd.sn.tesla.services to 208.67.222.222
Mar 26 13:33:26: query[A] hermes-prd.sn.tesla.services from 10.10.10.105
Looking at the Pi-hole debug log, a few things stand out:
While problem is happening:
[i] Distro: Debian
[i] Version: 11
[✗] dig return code: 10
[✗] dig response: dig: couldn't get address for 'ns1.pi-hole.net': failure
[✗] Error: dig command failed - Unable to check OS
After problem is resolved:
[✓] Distro: Debian
[✓] Version: 11
[✓] dig return code: 0
[i] dig response: "Raspbian=10,11 Ubuntu=20,22 Debian=10,11 Fedora=36,37 CentOS=8,9"
[✓] Distro and version supported
While problem is happening (way more UDP ports in use):
udp:0.0.0.0:631 is in use by cups-browsed
udp:0.0.0.0:49286 is in use by pihole-FTL
udp:0.0.0.0:33419 is in use by pihole-FTL
udp:0.0.0.0:53389 is in use by pihole-FTL
udp:0.0.0.0:49294 is in use by pihole-FTL
udp:0.0.0.0:41619 is in use by pihole-FTL
udp:0.0.0.0:33948 is in use by pihole-FTL
udp:0.0.0.0:41121 is in use by pihole-FTL
udp:0.0.0.0:59044 is in use by pihole-FTL
udp:0.0.0.0:58047 is in use by pihole-FTL
udp:0.0.0.0:39635 is in use by pihole-FTL
udp:127.0.0.1:5335 is in use by unbound
udp:0.0.0.0:5353 is in use by avahi-daemon
udp:0.0.0.0:60650 is in use by pihole-FTL
udp:0.0.0.0:44788 is in use by pihole-FTL
udp:0.0.0.0:58104 is in use by pihole-FTL
udp:0.0.0.0:33039 is in use by pihole-FTL
udp:0.0.0.0:42266 is in use by pihole-FTL
udp:0.0.0.0:56112 is in use by pihole-FTL
udp:0.0.0.0:47930 is in use by pihole-FTL
udp:0.0.0.0:60731 is in use by pihole-FTL
udp:0.0.0.0:56139 is in use by pihole-FTL
udp:0.0.0.0:40780 is in use by pihole-FTL
udp:0.0.0.0:55630 is in use by pihole-FTL
udp:0.0.0.0:39769 is in use by avahi-daemon
udp:0.0.0.0:42857 is in use by pihole-FTL
udp:0.0.0.0:59802 is in use by pihole-FTL
udp:0.0.0.0:59813 is in use by pihole-FTL
udp:0.0.0.0:33714 is in use by pihole-FTL
udp:0.0.0.0:53174 is in use by pihole-FTL
udp:0.0.0.0:42422 is in use by pihole-FTL
udp:0.0.0.0:57282 is in use by pihole-FTL
udp:0.0.0.0:36837 is in use by pihole-FTL
udp:0.0.0.0:46081 is in use by pihole-FTL
udp:0.0.0.0:46624 is in use by pihole-FTL
udp:0.0.0.0:41007 is in use by pihole-FTL
[✓] udp:0.0.0.0:53 is in use by pihole-FTL
udp:0.0.0.0:34361 is in use by pihole-FTL
udp:0.0.0.0:68 is in use by dhcpcd
udp:*:46246 is in use by avahi-daemon
udp:*:5353 is in use by avahi-daemon
[✓] udp:*:53 is in use by pihole-FTL
tcp:127.0.0.1:5335 is in use by unbound
[✓] tcp:0.0.0.0:53 is in use by pihole-FTL
tcp:127.0.0.1:8953 is in use by unbound
tcp:0.0.0.0:22 is in use by sshd
[✓] tcp:0.0.0.0:80 is in use by lighttpd
tcp:127.0.0.1:631 is in use by cupsd
[✓] tcp:127.0.0.1:4711 is in use by pihole-FTL
tcp:0.0.0.0:5900 is in use by vncserver-x11-c
tcp:0.0.0.0:9100 is in use by docker-proxy
[✓] tcp:[::]:53 is in use by pihole-FTL
tcp:[::]:22 is in use by sshd
[✓] tcp:[::]:80 is in use by lighttpd
tcp:[::]:5900 is in use by vncserver-x11-c
[✓] tcp:[::1]:4711 is in use by pihole-FTL
tcp:[::1]:631 is in use by cupsd
tcp:[::]:9100 is in use by docker-proxy
The debug log while the problem happened failed to upload. Here's a debug log once the problem resolved itself: https://tricorder.pi-hole.net/6cmuDp85/.
Any help diagnosing/debugging this issue would be greatly appreciated!
