DNS Over HTTPS
I followed this guide to setup DNS Over HTTPS. Seems to be working, but when I check using these links if DNS over HTTPS is enabled. It doesn't look so.
https://www.cloudflare.com/ssl/encrypted-sni/
Secure DNS = Question mark
DNSSEC = Red X
TLS 1.3 = Green check
Encrypted SNI =Red X.
https://1.1.1.1/help
Debug Information:
Connected to 1.1.1.1	No
Using DNS over HTTPS (DoH)	No
Using DNS over TLS (DoT)	No
Using DNS over WARP	No
AS Name	OpenDNS, LLC
AS Number	36692
Cloudflare Data Center	NRT
In the pihole admin page, I have enabled the Upstream DNS Server, and the line below in he custom 1 tab and clicked on save.
127.0.0.1#5053
Testing locally with dig.
dig @127.0.0.1 -p 5053 google.com
; <<>> DiG 9.10.3-P4-Raspbian <<>> @127.0.0.1 -p 5053 google.com
; (1 server found)
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 21589
; EDNS: version: 0, flags:; udp: 1452
; OPT=12: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 (".....................................................................")
;google.com.                    IN      A
google.com.             65      IN      A       216.58.197.142
;; Query time: 263 msec
;; SERVER: 127.0.0.1#5053(127.0.0.1)
;; WHEN: Tue Dec 17 11:29:45 JST 2019
;; MSG SIZE  rcvd: 138
You may have better success with a solution on the Cloudflared support pages.
