DNS not working from pihole
The issue I am facing:
Update fails due to inability to resolve hostnames
Details about my system:
I have 2 pi-holes set up for failover. They've been working great for years. I went to do a regular maintenance update and the secondary pi-hole (only active when the primary fails or isn't accessible) suddenly couldn't resolve domains so that it could update. After some testing I found that if I updated dhcpd.conf and changed
to
static domain_name_servers=1.1.1.1
I was able to do an update. However, resetting back to 127.0.0.1 will revert to things not updating again.
Not sure what happened or why it won't work anymore
Very little other than creating the failover system (following this guide https://www.reddit.com/r/pihole/comments/d5056q/tutorial_v2_how_to_run_2_pihole_servers_in_ha/). I've primarily just run regular updates via apt update and apt upgrade.
Tools > Generate Debug Log
Thank you.
https://tricorder.pi-hole.net/5fjl7p6z/
Nothing in your debug log indicates a problem. Pi-hole is receiving queries from network clients, processing them and returning results to the client.
-rw-r----- 1 pihole pihole 59K Oct 10 19:00 /var/log/pihole/pihole.log
   -----head of pihole.log------
   Oct 10 00:00:08 dnsmasq[583]: query[AAAA] icretrieveapi.myicomfort.com from 192.168.99.26
   Oct 10 00:00:08 dnsmasq[583]: forwarded icretrieveapi.myicomfort.com to 8.8.8.8
   Oct 10 00:00:08 dnsmasq[583]: query[A] icretrieveapi.myicomfort.com from 192.168.99.26
   Oct 10 00:00:08 dnsmasq[583]: reply icretrieveapi.myicomfort.com is <CNAME>
   Oct 10 00:00:08 dnsmasq[583]: reply p2cuic3tmaretrieveapi.trafficmanager.net is <CNAME>
   Oct 10 00:00:08 dnsmasq[583]: reply p2cuic3appretrieveapi3.azurewebsites.net is <CNAME>
   Oct 10 00:00:08 dnsmasq[583]: reply waws-prod-dm1-299.sip.azurewebsites.windows.net is <CNAME>
   Oct 10 00:00:08 dnsmasq[583]: reply waws-prod-dm1-299-40a9.centralus.cloudapp.azure.com is 20.118.48.7
   Oct 10 00:00:09 dnsmasq[583]: reply icretrieveapi.myicomfort.com is <CNAME>
   Oct 10 00:00:09 dnsmasq[583]: reply p2cuic3tmaretrieveapi.trafficmanager.net is <CNAME>
   Oct 10 00:00:09 dnsmasq[583]: reply p2cuic3appretrieveapi1.azurewebsites.net is <CNAME>
   Oct 10 00:00:09 dnsmasq[583]: reply waws-prod-dm1-179.sip.azurewebsites.windows.net is <CNAME>
   Oct 10 00:00:09 dnsmasq[583]: reply waws-prod-dm1-179-pork.centralus.cloudapp.azure.com is NODATA-IPv6
   Oct 10 00:00:09 dnsmasq[583]: query[HTTPS] gdmf.apple.com from 192.168.99.56
   Oct 10 00:00:09 dnsmasq[583]: forwarded gdmf.apple.com to 8.8.8.8
   Oct 10 00:00:09 dnsmasq[583]: query[A] gdmf.apple.com from 192.168.99.56
   Oct 10 00:00:09 dnsmasq[583]: reply gdmf.apple.com is <CNAME>
   Oct 10 00:00:09 dnsmasq[583]: reply gdmf.v.aaplimg.com is NODATA
   -----tail of pihole.log------
   Oct 10 18:59:48 dnsmasq[583]: query[AAAA] lastovo.hr from fe80::7be1:a296:69e:5bb8
   Oct 10 18:59:48 dnsmasq[583]: gravity blocked lastovo.hr is ::
   Oct 10 19:00:00 dnsmasq[583]: query[PTR] 8.99.168.192.in-addr.arpa from 127.0.0.1
   Oct 10 19:00:00 dnsmasq[583]: config 8.99.168.192.in-addr.arpa is <PTR>
   Oct 10 19:00:00 dnsmasq[583]: query[PTR] 1.1.1.1.in-addr.arpa from 127.0.0.1
   Oct 10 19:00:00 dnsmasq[583]: forwarded 1.1.1.1.in-addr.arpa to 8.8.8.8
   Oct 10 19:00:00 dnsmasq[583]: forwarded 1.1.1.1.in-addr.arpa to 8.8.4.4
   Oct 10 19:00:00 dnsmasq[583]: forwarded 1.1.1.1.in-addr.arpa to 1.1.1.1
   Oct 10 19:00:00 dnsmasq[583]: forwarded 1.1.1.1.in-addr.arpa to 1.0.0.1
   Oct 10 19:00:00 dnsmasq[583]: reply 1.1.1.1 is one.one.one.one
   Oct 10 19:00:00 dnsmasq[583]: query[PTR] 1.0.0.1.in-addr.arpa from 127.0.0.1
   Oct 10 19:00:00 dnsmasq[583]: forwarded 1.0.0.1.in-addr.arpa to 8.8.4.4
   Oct 10 19:00:00 dnsmasq[583]: reply 1.0.0.1 is one.one.one.one
   Oct 10 19:00:00 dnsmasq[583]: query[PTR] 8.8.8.8.in-addr.arpa from 127.0.0.1
   Oct 10 19:00:00 dnsmasq[583]: cached 8.8.8.8 is dns.google
Can you provide some specific examples where Pi-hole is not resolving hosnmaes?
Hmmm....I'm going to set dhcpd.conf back to 127.0.0.1 and see if it stays working. Thanks.
