I have configured pi-hole as the DNS and DHCP servers, I've given it a static IP and set local DNS to 127.0.0.1. DNS resolves for every device on the network and everything is running smoothly for all devices except the localhost. I have set Interface listening behavior to "Listen on all interfaces"
Ubuntu Bionic Beaver (18.04.4 LTS)
Hyper-V on Windows 10
The localhost can't resolve dns queries for itself. I can ping 8.8.8.8 but get no response when I ping google.com.
Please try again or contact the Pi-hole team for assistance.
The debug log is normal. You do have two IP's on the active interface, only one of which is being used by Pi-hole. If this was not intentional (and it appears it was not), then you may want to address this:
10.1.1.62/24 matches the IP found in /etc/pihole/setupVars.conf
169.254.71.228/16 does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
