Hi All,
_[Replace this text with what you think should be happening. Please include as much detail as possible including, but not limited to:
This is a standard install running on Raspberry Pi
PI400-4GB
4GB RAM LPDDR-32000
16GB SD Card with Raspbian OS
Pi-hole version is v5.17.1 (Latest: v5.17.1)
AdminLTE version is v5.20.1 (Latest: v5.20.1)
FTL version is v5.23 (Latest: v5.23)
NOTE: Upstream DNS server is a single Adguard IP (IPv4).
- The home router 192.168.1.1 serves DHCP and has itself as the DNS server in the distribution.
- I also deleted and recreated the (large) FTL.db
- Not using Conditional Forwarding in the DNS settings page.
- Rate limiting is not enabled.
The FTL and DNS services have been failing/hanging since the past few weeks and I couldn't find a resolution from the past threads about this topic, so creating a new one.
Currently the Web UI shows that the DNS service is not running and the settings page shows the error:
"PHP error (2): fsockopen(): unable to connect to 127.0.0.1:4711 (Connection refused) in /var/www/html/admin/scripts/pi-hole/php/FTL.php:47"
Please advise next steps to troubleshoot.
Thanks for all the help!
