dns should not fail and require a restart. Raspbian on rpi 3B+ in docker container
dns fails and i must run pihole restartdns
The problem may be that your router (which appears to be routing DNS requests from all clients to Pi-hole) is being rate limited:
*** [ DIAGNOSING ]: Pi-hole diagnosis messages
count last timestamp type message blob1 blob2 blob3 blob4 blob5
1 2023-03-02 10:16:51 RATE_LIMIT 192.168.1.1 1000 60
-----tail of pihole.log------
Mar 2 10:20:08 dnsmasq[6123]: config error is REFUSED (EDE: blocked)
Mar 2 10:20:08 dnsmasq[6123]: Rate-limiting dt.adsafeprotected.com is REFUSED (EDE: blocked)
Mar 2 10:20:08 dnsmasq[6128]: query[A] dt.adsafeprotected.com from 192.168.1.1
Mar 2 10:20:08 dnsmasq[6128]: config error is REFUSED (EDE: blocked)
Mar 2 10:20:08 dnsmasq[6128]: Rate-limiting dt.adsafeprotected.com is REFUSED (EDE: blocked)
Yes this looks likely. nice catch. i found the docs on how to change the rate limiting.
