Pi-Hole installed on Raspberry PI, available on IP address 192.168.1.54 should work as my local network primary DNS to block blacklisted domains.
My router is on 192.168.1.1
My Raspberry Pi with Pi-Hole installed is on 192.168.1.54
I set 192.168.1.54 as the primary DNS on the router.
Now, on my computer (192.168.1.69) I test a domain that should be blocked.
- Using raspberry pi as NS:
dig @192.168.1.54 pewnyzabieg.pl
pewnyzabieg.pl. 2 IN A 0.0.0.0
it's ok, resolved as 0.0.0.0 so I assume blocking works
- Using my router as NS:
dig @192.168.1.1 pewnyzabieg.pl
pewnyzabieg.pl. 20327 IN A 185.253.212.22
it's incorrect because it resolved the domain name to its real IP address, not blocked.
Let's check the router logs:
- No reply from 192.168.1.54(+10) for pewnyzabieg.pl, now asking 87.204.204.204
- Resolved UDP query for pewnyzabieg.pl via 87.204.204.204
So, domain was not resolved my Pi-Hole and the secondary DNS has been used.
What did I do wrong, that the Pi-Hole works fine from my computer, but does not resolve domains when asked from my router?
[✓] Your debug token is: https://tricorder.pi-hole.net/nrb41eGa/
Edit:
Additional information.
I observe Pi-Hole logs with pihole -t
and there is no log when I try to resolve the host via my router and it works fine when I send the request directly to the raspberry pi machine.
