DNS delivery of Discovery of Network-designated Resolvers (DNR)
Thinking about it more, you can do this easily enough now with Pi-hole, using dnsmasq's option dns-rr but you need to encode the option yourself.
To be clear, this does not add dot, doq or doh functionality to Pi-hole. This is for use in cases such as described by @a7md0 to direct clients to installed proxies capable of handling that conversion.
The python code at the end of this post can generate the line for you, and the result would need to be entered into the misc.dnsmasq_lines setting in Pi-Hole. You would also need to make sure that dns.specialDomains.designatedResolver is disabled in the all settings dns tab.
rob@builder:~/git/svcb-encoder$ ./svcbencoder.py
Domain name : (press enter for pi.hole)
IP address :1.2.3.4
Please select server type:
For each of the following (dot, doh, doq), please enter 'y' or 'n'
DNS over TLS - dot (y/n)y
DNS over QUIC - doq (y/n)n
DNS over HTTPS - doh (y/n)y
DOH path ( press enter for '/dns-query{?dns}' ) :
dnsmasq.conf option:
--dns-rr=_dns.reverse.arpa,64,000102706904686F6C65000001000702683203646F740004000401020304000700102F646E732D71756572797B3F646E737D
Pi-Hole misc.dns.masq_lines value:
Enter into settings, expert, all settings, miscellaneous, misc.dnsmasq_lines
Confirm by running
dig SVCB _dns.resolver.arpa @pi.hole :
rob@builder:~/git/svcb-encoder$dig SVCB _dns.resolve.arpa @pi.hole
; <<>> DiG 9.18.33-1~deb12u2-Debian <<>> SVCB _dns.resolve.arpa @pi.hole
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 15648
;_dns.resolver.arpa.		IN	SVCB
_dns.resolver.arpa.	0	IN	SVCB	1 pi.hole. alpn="h2,dot" ipv4hint=1.2.3.4 key7="/dns-query{?dns}"
;; Query time: 31 msec
;; SERVER: 192.168.1.228#53(192.168.1.228) (UDP)
;; WHEN: Tue May 06 14:22:56 AEST 2025
;; MSG SIZE  rcvd: 107
Code:
#!/usr/bin/python3
import dns.rdata # pip3 install dnspython
import io
name = str(input("Domain name : (press enter for pi.hole)"))
name = name if name else "pi.hole"
ipaddr = str(input("IP address :"))
print("Please select server type:")
print("For each of the following (dot, doh, doq), please enter 'y' or 'n'")
nalpn = int(0)
dot = str(input("DNS over TLS - dot (y/n)"))
if dot == "y":
  nalpn = nalpn + 1
doq = str(input("DNS over QUIC - doq (y/n)"))
if doq == "y":
  nalpn = nalpn + 2
doh = str(input("DNS over HTTPS - doh (y/n)"))
if doh == "y":
  nalpn = nalpn + 4
match nalpn:
  case 1:
    alpn = "dot"
  case 2:
    alpn = "doq"
  case 3:
    alpn = "doq,dot"
  case 4:
    alpn = "h2"
  case 5:
    alpn = "h2,dot"
  case 6:
    alpn = "h2,doh"
  case 7:
    alpn = "h2,doq,dot"
  case 0:
    print("Nothing entered. Exiting...")
    quit
rclass = dns.rdataclass.IN
rtype = dns.rdatatype.SVCB
rdata = '1 '+name+'. alpn="'+alpn+'" ipv4hint="'+ipaddr+'"'
if nalpn >= 4:
  dohpath = str(input("DOH path ( press enter for '/dns-query{?dns}' ) :"))
  dohpath = dohpath if dohpath else "/dns-query{?dns}"
  rdata = rdata + 'key7="'+dohpath+'"'
rd = dns.rdata.from_text(rclass, rtype, rdata)
f = io.BytesIO()
rd.to_wire(f)
wire_data = f.getvalue()
print ("dnsmasq.conf option:")
print ("--dns-rr=_dns.resolver.arpa," + str(rtype) + "," + wire_data.hex().upper())
print ("Pi-Hole misc.dns.masq_lines value:")
print ("Enter into settings, expert, all settings, miscellaneous, misc.dnsmasq_lines")
print ("dns-rr=_dns.resolver.arpa," + str(rtype) + "," + wire_data.hex().upper())
Thank you! This way really worked and it's exactly what I wanted to achieve. I will need to test it further on my setup
Although the test command should be (as per what we override using dns-rr)
dig SVCB _dns.reverse.arpa @pi.hole
Yikes. Thanks.
The script output has been corrected to "_dns.resolver.arpa".
Thanks a ton for the script, I slightly tweaked it to support multiple IPs, IPv4 and IPv6 as well as ports.
code:
#!/usr/bin/python3
import io
ipaddr = str(input("IPv4 address : (comma delimited, no port)"))
ip6addr = str(input("IPv6 address : (comma delimited, no port, press enter for empty)"))
port = str(input("Port : (press enter for 443)"))
port = port if port else "443"
nalpn = int(0)
if dot == "y":
  nalpn = nalpn + 1
if doq == "y":
  nalpn = nalpn + 2
if doh == "y":
  nalpn = nalpn + 4
match nalpn:
  case 1:
    alpn = "dot"
  case 2:
    alpn = "doq"
  case 3:
    alpn = "doq,dot"
  case 4:
    alpn = "h2"
  case 5:
    alpn = "h2,dot"
  case 6:
    alpn = "h2,doh"
  case 7:
    alpn = "h2,doq,dot"
  case 0:
    quit
rdata = '1 '+name+'. alpn="'+alpn+'" port="'+port+'" ipv4hint="'+ipaddr+'"'
if ip6addr:
  rdata = rdata + ' ipv6hint="'+ip6addr+'"'
if nalpn >= 4:
f = io.BytesIO()
rd.to_wire(f)
Also note that most DNS providers usually split dot/doq and h2 / h3 on two different lines.
This script could also be updated to add h3 support.
Thanks for this. It’s a nice addition to my DoH setup.
