I have this router: ADB Crow AX VP4412.
I have attached the dhcp configuration menù.
Is there a way to see all ip address in query log changing some options?
192.168.1.110 is Pi-Hole.
Thanks
Thanks
Perhaps, if that router supports configuring its DHCP server to distribute your Pi-hole host machine's IP.
You'd have to consult your router's documentation and support channels for those respective details.
Apparently you already configured your router to distribute Pi-hole as a name server.
Usually, after changing these router settings, you need to renew the DHCP leases on each device.
Already did. Inside Query Log I can see only one client: 192.168.1.1 (my router).
Pi-Hole works but I can't see the clients ip.
Do you have a Windows, MacOS or Linux client to test?
If so, run below one on it and copy/paste the output to here pls?
nslookup pi.hole
It should show you what DNS server is addressed for that particular pi.hole query:
C:\>nslookup pi.hole
Server: ph5a.home.dehakkelaar.nl
Address: 10.0.0.2
Address: 10.0.0.2
You can also run below one on the Pi-hole host to check what dns-server is/are advertised via DHCP:
pi@ph5b:~ $ pihole-FTL dhcp-discover
dns-server: 10.0.0.2
There should only be the Pi-hole IP for DNS and no others!
