DNS cache issue
Enabling/Disabling pihole, changing settings, rebooting the system, Black/Whitelisting,
and updating gravity lists all will clear the cached DNS entries.
DNS cache is being cleared!
https://tricorder.pi-hole.net/cfahm1i63l
What is leading you to believe that the Pi-hole FTL cache is not being cleared?
I do not have technical knowledge about Pi-hole FTL, so I do not know if it's normal behavior to clear the cache every time I disable/enable the pihole... for me it sounds weird that the cache is cleared for any changes are made on the system... in this way, it is almost useless idea of DNS caching since it will reset on every gravity update..
From your post it's not clear what behavior you expect and what you are seeing. Please clarify.
Is it normal that the DNS cache are zeroed when i enable/disable the pihole? Or when update the gravity lists?
Yes it's normal.
Gravity triggers
Enable triggers
Which means:
They question is: Does it really need to a reload,which flushes the cache, or would a reload-lists be sufficient?
Thank you, you have concluded what I wanted to say!
@Developers
Do we really need a reload instead of reload-lists after each gravity run and after dis/enabling pihole?
