Hi!
Bypassing clients via 04-bypass.conf works perfectly:
Create 04-bypass.conf in /etc/dnsmasq.d
dhcp-option=tag:googlesdns1,option:dns-server,8.8.8.8
dhcp-host=8C:XX:XX:XX:XX:XX,set:googlesdns1,Hostname
(see Let specific clients bypass pi-hole in FTLDNS (was working with dnsmasq) - #6 by RamSet - thanks to RamSet) . But only with ipv4.
Pihole is the DHCP Server. If I use ipv4 and ipv6, the bypass doesnt work. Clients try the ipv6 DNS first...
Is there a solution for bypass DNS ipv6 around pihole for special clients? Thank you and sorry for my bad english...
