DNS and FTLservice should be running
DNS and FTL service aren't running
x02t9apk0c
x02t9apk0c
What are the outputs of the following commands from the Pi terminal?
sudo netstat -nltup | grep 'Proto\|:53 \|:5053 \|:5353 \|:8953 \|:67 \|:80 \|:471'
##sudo netstat -nltup | grep 'Proto\|:53 \|:5053 \|:5353 \|:8953 \|:67 \|:80 \|:471'
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 5861/lighttpd
tcp6 0 0 :::80 :::* LISTEN 5861/lighttpd
udp 0 0 0.0.0.0:5353 0.0.0.0:* 324/avahi-daemon: r
udp6 0 0 :::5353 :::* 324/avahi-daemon: r
##sudo service pihole-FTL status
pihole-FTL.service - LSB: pihole-FTL daemon
Active: active (exited) since Thu 2020-01-23 20:58:14 WET; 22min ago
Process: 6241 ExecStart=/etc/init.d/pihole-FTL start (code=exited, status=0/SU
jan 23 20:58:13 raspberrypi systemd[1]: Starting LSB: pihole-FTL daemon...
jan 23 20:58:13 raspberrypi pihole-FTL[6241]: Not running
jan 23 20:58:13 raspberrypi su[6270]: (to pihole) root on none
jan 23 20:58:13 raspberrypi su[6270]: pam_unix(su:session): session opened for u
jan 23 20:58:14 raspberrypi pihole-FTL[6241]: dnsmasq: bad dhcp-option at line 2
jan 23 20:58:14 raspberrypi su[6270]: pam_unix(su:session): session closed for u
jan 23 20:58:14 raspberrypi systemd[1]: Started LSB: pihole-FTL daemon.
This shold not appear. What is the output of the following command from the Pi terminal:
pihole-FTL dnsmasq-test
I had a typo on one of the configs.
Thanks
